abs inop?
Old Mar 28, 2003 | 05:07 PM
1FASASZ's Avatar
abs inop?
I just got done installing hooker lt's and now my abs inop light comes on. Has anyone else had this problem after a header install or does anyone know what it could be?Thanks
Old Mar 28, 2003 | 05:14 PM
twells's Avatar
i'm not sure about after the header install, but my light came on when i was having charging/alternator problems.
thomas
Old Mar 28, 2003 | 05:25 PM
1FASASZ's Avatar
Is there anyway to tell if your abs realy isn't working. Can they still be work when the abs inop light is on.
Old Mar 28, 2003 | 05:40 PM
twells's Avatar
the light being on doesn't always mean that they are not working. actually it is quite common for the abs light to come on sometimes and then go away with nothing ever happening. there must be a glitch in the system or something.
thomas
Old Mar 28, 2003 | 07:02 PM
norcalstreet's Avatar
Follow the ABS sensor wire from the rearend up to the engine and make sure that it didn't come to close to the headers at some point. A few other things to check would be the fuse of the ABS sensors on the rearend as they commonly come out.
Old Mar 28, 2003 | 07:08 PM
What usually happens to cause this right after a header install is plug wires re-routed too close to an ABS harness. The electromagnetic field will disrupt the ABS signals. Make sure you have some space between them.
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
