9mpg...wtf
Im so pissed right now, last tank I got 11mpg...I used to get 17mpg all day long. Anyway, after that tank I decided I was going to baby my car, I shifted below 2500 98% of the time, went WOT 3 times...and got 9mpg...whats the deal here? I scanned it and one o2 is at like 815 when I go WOT and the other is 925 or so...is the one at 815 reading that and adding more fuel to that side and getting ride of my gas or what? I just don't get it on what could happen all of the a sudden, aside from the o2 reading being a little low, no codes or anything.
:cry: :cry: :cry: |
Re: 9mpg...wtf
fuel filter??? when was the last time you had it changed out?
hopefully you don't have my luck....with my car it never seems to that easy |
Re: 9mpg...wtf
sucks too with gas prices being so freakin' high. I feel your pain
Re: 9mpg...wtf
I would check/replace the Fuel filter, air filter, plugs, wires. Then see how it does after that.
Tyler |
Re: 9mpg...wtf
air filter is new, plugs are pretty new, wires aren't very old. Fuel filter I have no idea....here is my question before I change that. If its clogged and letting less gas through...wouldn';t i get better gas mileage or the car run like ass? Im not questioning it, I just don't understand it and would like some info ;)
The car feels great btw. |
Re: 9mpg...wtf
Maybe o2 sensors? Is the car throwing any codes? Maybe running too cold, it can do that with the lower temp thermostat.
Re: 9mpg...wtf
no codes with datamaster, the only thing that looks slightly wrong is one o2 reads 100 less than the other at WOT 800/900. Too cold...hmmm, I dunno, maybe, but I don't think so, I have had the 160* in for a while.
Re: 9mpg...wtf
What temp does the scanner say the ECM is showing? If the temp sensor is bad and the ECM thinks the engine is still cool, it will richen the mixture up.
2 other things you want to check right away. See if the oil smells like fuel. If so you probably have a dead cylinder. The other thing is either use a themometer on the ex manifold or pull one plug wire at a time until you pull one that has no effect on the way the engine runs. I suspect you have a dead hole. BTW if your oil smells like fuel don't use the car until you find the problem. Cylinder wash down or "souping" is bad for the cylinder walls. Dave |
Re: 9mpg...wtf
what do o2s show while cruising?
Re: 9mpg...wtf
2 other things you want to check right away. See if the oil smells like fuel. If so you probably have a dead cylinder. The other thing is either use a themometer on the ex manifold or pull one plug wire at a time until you pull one that has no effect on the way the engine runs. I suspect you have a dead hole. BTW if your oil smells like fuel don't use the car until you find the problem. Cylinder wash down or "souping" is bad for the cylinder walls. Dave I will try smelling the oil, but to be honest I don't think I have a dead cylinder. The car pulls pretty well. The last tank I got 11mpg I raced and beat an LS1 WS6 and actually pulled past him in 3rd, beat a 400fwhp eclipse from a roll...so the car appears to be running fairly decent, although I think it is kinda rich...obviously. |
Re: 9mpg...wtf
One thing is that when the car is idling sometimes the readings move around like 700-900...thats pretty nuts for idle isn't it? |
Re: 9mpg...wtf
mine does the same thing. Im goin to try replacing the 02's since Ive never replaced them. one or both could easily be a little off, throwin off the mixture and makin it run rich. or you could have an inj. thats not working properly. either rich or lean. but that would prolly throw a code. do you have a fuel meter? if so, hook it up and make sure the press. doesnt drop off by itself when you key up the ign.w/o the eng. running. it should hold press. for a while.
chris |
| All times are GMT -5. The time now is 09:22 AM. |
