98 Front end on a 93
I just bought headlights, fenders, nose, and hood for a 98 camaro and i am planning on putting it on my 93. Has anyone done this and is there anything i should know before doing it?
Re: 98 Front end on a 93
You will also need the brackets that hold everything to the frame of the car. And might need the plastic junk that goes under the bumper cover, I'm not sure if it's different. Other than that, just start pulling pieces off until you get that done. And when you go to install the new parts, start with the fenders and get the door gap as close to where you want it. Then install the hood and get the lines just perfect. Then install the front bumper cover. That will make it the easiet to get everything as close as possible. Just take your time and be patient.
PublicEnemy1
Apr 7, 2015 12:21 PM
