96 T/A missing really bad
Old Mar 26, 2005 | 08:06 PM
Irocdriver89's Avatar
when i start the car there is a really bad miss, then when i drive it it miss off the line then pulls really hard to the top of rpms. And every time i down shift and punch it, it dies and then pulls hard so it's missing. And my check engine light is on and flashing. When i pulled the code it's random miss fire. Any help would be great i'm pissed off and don't know what to do!!!!
Old Mar 26, 2005 | 08:48 PM
slverbullet's Avatar
Re: 96 T/A missing really bad
i'm not an expert mechanic, but i would recommend starting with the basics. how are your plugs and wires? if theyre good, possibly the opti.
Old Mar 26, 2005 | 09:00 PM
valter's Avatar
Another vote for plug and wires. Clean your MAF too.
Old Mar 27, 2005 | 02:47 AM
the plugs are clean almost look brand new but the wires are bad i think they look old and are even taped together which could cause cross firing right.i think it's the wires because every now and then it runs fine and when i'm on the freeway forceing more sparks the car almost runs normal any other opinions.
Old Mar 27, 2005 | 06:40 AM
BRIAN93Z28's Avatar
go out tonite when its dark outside and start your car, open the hood and check to see if you can see any sparks coming from the engine bay. Could be a wire got sliced or corroded open, that can cause it right there. Same thing happened to mine. Like the other guy said, start with the basics first.
markzzzz
May 8, 2015 09:21 AM
shroyvin56
Apr 19, 2015 09:40 PM
captcorvette
Mar 7, 2015 12:37 PM
DetroitZ28
Feb 13, 2015 07:33 AM
