CamaroZ28.Com Message Board
-   -   95 z28 no start.... help (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/95-z28-no-start-help-701338/)
brokegenetic Jul 25, 2009 12:34 PM
I have a 95 vert z28 stock it was running perfectly and one morning would not start.
Original opti with newer cap rotor(riveted & sealed), the motor cranks and sometimes starts
I can get it to start if pedal is wot, but idles as if its lean and dies if i punch it and get rev it up slowly though.
At the beginning it was getting no injector pulse(when it was not starting) now it gets a weak pulse (with noid light), injectors get full voltage.
Fuel pressure has been constant whether car started or not, 41 prime and 37-38 running constant pressure.
Check gauges light is on, gauges work, light was on before I removed waterpump.
I tried replacing opti with a good used unit and same symptoms.
Today I will be checking and cleaning all grounds.
Is there any way to check ignition switch without replacing it yet?
I don't have a scanner but will be hunting my neighbor down so I can use his
Any ideas?
d2stephen Jul 31, 2009 11:23 AM
I'm having just about the same exact problem. Did you happpen to find a solution?
Hal Fisher Jul 31, 2009 12:12 PM
Weak battery or bad coil or IC module maybe?
Hal
brokegenetic Aug 5, 2009 05:20 PM
Okay its been a while cause I've been working but finally got my hands on a snap on scanner the car no longer starts, still cranks,
tried one used opti and one new, same symptoms; sparks, cranks, no injector pulse, the scanner gave me a code 18(no crank signal) everything else checks out.
Scanner states it might be an ecm problem and to check all grounds, I have cleaned the ecm ground on the block, the one on the driverside/coil stud area, new strap, cleared codes and still no go, same code pops up
Any ideas?
brokegenetic Aug 5, 2009 05:52 PM
scanner just started going into mismatch communication/no communication to spitting out just about every code there is like 52 53 then it went back to normal just sending code 18 and 48( but thats cause I have the maf off)
Injuneer Aug 6, 2009 05:29 AM
DTC 18 is a problem with the injector circuits. Use Shoebox's LT1-specific code list, not the generic one in the scanner.
http://shbox.com/1/Dtcs.htm
brokegenetic Aug 6, 2009 08:04 PM
What would cause a dtc 18? Any test I can do to verify pcm is good?
Injuneer Aug 6, 2009 09:45 PM
The PCM is seeing the wrong voltage on one (or more) of the injector circuits when it tries to fire the injector. PCM supplies a ground to fire.
Key on, check the pink wire to each injector connector, measuring against a good engine ground. Should have 12V on each pink wire.
Connector off the injectors, measure the resistance across the two pins on the injector. Should be 12-15ohms,
Get a set of 'noid lights, crank the engine and verify that each injector is getting a ground pulse from the PCM, to fire the injector.
That will verify all parts of the injector circuits, including the PCM.
brokegenetic Aug 7, 2009 04:54 PM
With key on I'm getting 12.99 to 13V
injectors are from 12.5 to 12.8 ohms
got the noid lights and the injectors are not pulsating, lights just stays on
monday I'll take the pcm to a place that supposedly can check them,
anything else I can do till then?
brokegenetic Aug 26, 2009 10:23 PM
Update
Got another pcm in and still no good, same symptoms and still dtc 18:mad:, I guess I'll tear the plastic covering and check every wire tomorrow:no:
brokegenetic Aug 27, 2009 02:05 PM
Double checked everything, replaced terminals on ground wires due to some corrosion and nothing.
Decided to go with the code the snap on scanner gave me which was no crank signal and started checking found that there was no juice going to the crank fuse by the driver's side door and then traced it lower
I think its the ignition switch and connector
brokegenetic Aug 27, 2009 02:46 PM
http://s308.photobucket.com/albums/k...tionswitch.jpg
http://s308.photobucket.com/albums/k...hconnector.jpg
meissen Aug 27, 2009 03:15 PM
Yikes! That doesn't look too swift at all!
brokegenetic Sep 8, 2009 10:58 AM
Installed the switch and connector on saturday and runs like a champ. Starts on first crank everytime!!! :freakout:
95mysticta Sep 14, 2009 04:06 PM
im having the exact same issues! sent you a PM
