95 Z overheating fans not turning on
Hi My 95 Z is overheating ive changed the water pump,thermostat and bleed the system now ive noticed that the fans arent turning on when it gets hot.The only time the fans turn on is when the ac is tuned on, ive checked the relays so im wondering if anyone can give me some pointers.thanks
Re: 95 Z overheating fans not turning on
Coolant temp sensor in the top of the water pump might be too blame.. Change that out and see what goes from there.. :)
i replaced that with the water pump it broke in pieces when i was trying to get it off sorry i didnt mention that.so im completely stuck now its wierd ive replaced everything that it could be.
Give more details on the temps you are seeing. Not everyone's idea of "overheating" is the same.
ok sorry i should have made it more clear it goes from the middle of the gauge which is where it always is to the red 260.also it cools down when i turn the air on because the fans kick in.
Check again for air in the system and for the proper level of coolant. More info can be obtained by watching the temp reported to the PCM with a scan tool and also observing the fan ON status.
ok i just bleed the system again and it ok how would i go about checking the temp, what temp are they suppose to come on.
chech the fan relay for the temp when u turn on the ac the low fan kicks on only or just put a switch on it go to orileys and buy a toggle switch. Hook either wire to a power source and the other one to the fans and also run a fuseable link on it 20 should be fine. Good luck :cool:
I had the same problem...Check your fuseable links. the group of wires coming out of the battery connecter on the fender well (pass side) the wires have what looks like black shrink wrap on them. look at them and make sure they arent burned.
Matt |
ok ill try that just got off work so ill have to try it tomarrow i really appreciate the help.
This is actually awesome info. I have a 93 that I bought recently since I wrecked my old one. Anways the guy I bought it from installed a new radiator and the car does the same thing but takes longer maybe about 20 min and in stop and go traffic when the temp gauge goes up. But as soon as i start driving again it goes down? Seems like similar issues here.
