Coil resistance
Coil resistance
I have a coil...the primary is fine....
seconday is whats getting me.......... Checked it several time with 2 meters, I am getting 7700 and 8700 reading. I would say its weak, it still works but could it be getting weak?
My manual says spec is 5k-7k and it must be within the spec....
Another thing is heat. These things often fail under heat stress moving the hair-thin wires around after they break - Sometimes it is making contact, then it doesnt. You can simulate heat stress with a heat gun if you want to look at it on a bench tester, it might take a while - just don't melt the thing.
Oh well, I just got this http://store.summitracing.com/partde...5&autoview=sku
I'm just going to use it from now on
jackpawt883
09-10-2015 08:53 PM
