94 Z slow to respond....wheezing at times
My 94 LT1 Z28 is just wheezing these days.
When I got to put my foot on the gas I feel like there is little to no horsepower there and it takes a few more mili seconds than normal for it to pick up and go..
The car was never really an amazingly fast car but something is dying on it or perhaps broken.
With the windows down I hear more wheezing coming out of the engine rather than growls.
Any guesses or similiar stories?? I want my camaro to be faster, just not the fastest, I want a cruiser that has the power there in case I need it.
Haven't done anything to the engine except ram air from rk sport and a new radiator after crashing.
Mike
Mike
alright since you insist
Since you guys are saying I need to change things in my car what do you suggest for new parts:
Plugs and wires?
fuel filter?
can you change your O2 sensors?
how do you clean the MAF?
Also did you guys check your CAT on your own or did you take it someplace?
I really appreciate it guys.
Mike
Plugs and wires?
fuel filter?
Mike
Plugs and wires?
fuel filter?
Mike
Plugs and wires?
fuel filter?
Mike
Alot of companies make plug wires that work with our cars, I have used Taylor 8.0 wires but then burnt one. Now I'm running the MSD 8.5 superconductors, they work well also but were alot thicker than stock so I had to mod the stock hardware so that they fit properly. Maybe someone else can suggest a better wire to use on stock application.
Fuel filter you can use a stock replacement it's not expensive.
For the MAF you can just remove the MAF from the intake tract, dissassemble the actual black sensor from the 2 metal housings (be very careful when you handle it) And get some MAF sensor cleaner from your local parts store and clean the sensor elements with a Q-tip without applying too much pressure.
For the cat, when I suspected mine was acting up, I just had it replaced with an exhaust cutout but if you live in an area where they do strict emissions testing I don't recommend this
Btw when did you put your ram air in? Have you cleaned the air filter or replaced it since?
Plugs and wires?
fuel filter?
Mike
Plugs and wires?
fuel filter?
Mike
oil temp
Any ideas on perhaps why the oil temp on my car starts out in the middle and then after running for about 20 minutes drops down into the orange where the low markers are? if I had to guess it is at maybe 20% to 25% of what the oil temp gauge can be at.
thanks
thanks
