94 LT1 fuel injectors into a 93 ??
would there be any benefit in doing this? If I remember correctly, the 94's were bigger than the 93's. Can I just swap the injectors out with no problem or would I need to do anything else?
Yes, 94 injectors will work in a 93. The 93 injectors are 22 lb/hr and 94 are 24 lb/hr. In programming, the 93 are set as 24 lb/hr and the 24's are set as 25. The difference isn't that big so they should work fine.
| All times are GMT -5. The time now is 01:09 AM. |
