94 LT1 fuel injectors into a 93 ??
would there be any benefit in doing this? If I remember correctly, the 94's were bigger than the 93's. Can I just swap the injectors out with no problem or would I need to do anything else?
Yes, 94 injectors will work in a 93. The 93 injectors are 22 lb/hr and 94 are 24 lb/hr. In programming, the 93 are set as 24 lb/hr and the 24's are set as 25. The difference isn't that big so they should work fine.
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
