are the 700r4 and 4l60e the same thing?
Old Apr 24, 2003 | 10:24 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
just what the title says... also... if they arn't is one compatable with the other? which one did my 95 formula come with? which one is better? cheaper?
Old Apr 24, 2003 | 10:34 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i too would like to get this clarified-
I believe the 700R is a 4L60
a 4L60E is an electronically controlled 4L60
And my main question-
are the TQ converters interchangeable?
Old Apr 24, 2003 | 10:41 AM
hairbear21's Avatar
I believe that the 700 R4 and the 4L60 are the same thing, and in 94 the 4L60E came out. 700R4 and 4L60 parts should be interchangeable, but I am unsure of the 4L60E because it is electronically controlled. As for your car, it is the 4L60E
Old Apr 24, 2003 | 11:10 AM
97Z-M6's Avatar
your exactly right trey , and ill check on the converter ?
Old Apr 24, 2003 | 12:03 PM
97Z28TTopTerror's Avatar
i just got my new tranny ...with a 2800 stall converter tranny cooler...and all the specials.
Old Apr 24, 2003 | 03:07 PM
RTICWOLF's Avatar
These transmissions are basically the same and the parts do interchange just fine.
Just be sure to match your spline and you will be fine on the parts from either or......
Old Apr 24, 2003 | 05:17 PM
allmotorta's Avatar
Absolutely. I bought a converter off my buddy that was in his 96 A4 4l60e, I bolted it right up to my 93 4l60, and it works fine. So theres your proof
Old Apr 24, 2003 | 05:46 PM
mkent's Avatar
so if the 700 r4 is the same as the 4l60, then why did GM change the names of them? i'm not trying to disagree with any of you guys, i just would like to know what the difference is.
also, in theory it is possible that the 700r4 TC work in the 4l60, but not work in the 4l60e...maybe something extra is needed to make it work with the electronics? if anyone has tried a 700r4 in a 4l60e and has no problems, then i'd be pretty angry that all these companies have been ripping us all these years. it seems as if anything with "LT1" in the application has a 300% discount!
also, i was just looking through my summit, and B&M lists a TC for 93-96 4l60e...but no 97? do i not have a 4l60e in my 97 or does summit not realize the camaro was produced after 96?
thenewkid
Apr 12, 2015 07:42 PM
jimmybandana
Mar 22, 2015 07:44 PM
Jan 5, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
Hal Fisher
Sep 14, 2002 09:36 PM
