60' Times
Post your best 60' time on street tires and tell me whether you did a burnout or not. Also, What kind of street tires?
Hello,
My best 60' on a Nitto 555 with a three to four second burn out was 1.907. I switched to a DR and managed 1.84 before changing my rear gear from a 2.73 to 3.73. Now I have not managed to hook yet with the 3.73 but am trying some new things tonight. |
my best was last weekend with a buddies Hoosiers DR
60' was 1.915 The tire is kinda skinny if you ask me 9" or something like that. |
Re: 60' Times
Originally posted by rghyland Post your best 60' time on street tires and tell me whether you did a burnout or not. Also, What kind of street tires? |
2.003 with 2.73 gears, kdw tires, and some stupid ass burnouts, did i mention no tire spin eaither, dead hook
With all my mods (except the Vigi 3200 and Race Trans) I was cutting 2.0 60 foot times all day long. I did this on a Dunlop 5000 sport street tire.my only suspension mods were Control Arms and Subframe connectors.
I cut some 2.0's with some bald Firestone Firehawks (stock). Dont know how, but they bit hard, and I did do a burnout. Actually two, I heated them up in the water box, then cleaned them off before pulling to the line. Can't hook up now w/out my et streets.:D
Benji |
If by street tires, you mean anything DOT approved: 1.65 60' on 28x11.5x15 ET Streets.
If by street tires, you mean regular old street radials, no drag radials or street slicks: 1.99 on 275/60/15 BFG Radial T/A's. |
Best of all 3
Street: 2.11 Nitto DR 1.78 ET Streets 1.75 |
2.1 60' Kumho Ecsta 712's. Stock suspension and 3600 stall.;)
Originally posted by WheelmanZ28 With all my mods (except the Vigi 3200 and Race Trans) I was cutting 2.0 60 foot times all day long. I did this on a Dunlop 5000 sport street tire.my only suspension mods were Control Arms and Subframe connectors. One thing about Water-box burnouts, MAKE SURE U LET OFF THE BRAKE SO THAT U CONTINUE TO BURNOUT - OUT - of THE WATER BOX. I see too many newbs at the track that do a burnout, and stay in the water box, and drive out :rolleyes: Their tires are still wet and they end up with 60s of like 2.4. |
Best on BFG's 2.02
Best on BFG drags 1.81 Best on 27/10.5/15 ET streets 1.67 In a 4500 lb boat. HVY SS |
1.923 Best of Firehawk SZ50's. Consistent mid 1.9X short times. Switch to Nitto DR's and muster a best o 1.96 one time.
Street: 1.97 Bridgestone Potenza RE730 (1 time only street tire run-30 psi, light burnout)
Nitto DR: 1.70 (18 psi) M/T ET Drag: 1.55 (16 psi) |
Nitto DR's, about 26psi, 1.92 60'
| All times are GMT -5. The time now is 09:51 AM. |
