60' Times
Old Jun 27, 2003 | 03:53 PM
rghyland's Avatar
60' Times
Post your best 60' time on street tires and tell me whether you did a burnout or not. Also, What kind of street tires?
Old Jun 27, 2003 | 04:08 PM
383Z4ME's Avatar
Hello,
My best 60' on a Nitto 555 with a three to four second burn out was 1.907. I switched to a DR and managed 1.84 before changing my rear gear from a 2.73 to 3.73. Now I have not managed to hook yet with the 3.73 but am trying some new things tonight.
Old Jun 27, 2003 | 04:31 PM
1BadBrd's Avatar
my best was last weekend with a buddies Hoosiers DR
60' was 1.915
The tire is kinda skinny if you ask me 9" or something like that.
Old Jun 27, 2003 | 04:50 PM
Smokn '94 Z's Avatar
Lightbulb Re: 60' Times
O.K. Street tires 60's is what you are asking for... I cut a 1.81 & 1.81 - 1.90 consistantly on my BFG Comp TA's 275 45 17's... I would run them at about 20 PSI & no I really didn't do a burnout. I would give them a quick spin to clean them off a bit..
Old Sep 16, 2003 | 09:42 PM
blazzinbird's Avatar
2.003 with 2.73 gears, kdw tires, and some stupid *** burnouts, did i mention no tire spin eaither, dead hook
Old Sep 16, 2003 | 10:24 PM
WheelmanZ28's Avatar
With all my mods (except the Vigi 3200 and Race Trans) I was cutting 2.0 60 foot times all day long. I did this on a Dunlop 5000 sport street tire.my only suspension mods were Control Arms and Subframe connectors.
Old Sep 16, 2003 | 11:00 PM
Sweetred95ta's Avatar
I cut some 2.0's with some bald Firestone Firehawks (stock). Dont know how, but they bit hard, and I did do a burnout. Actually two, I heated them up in the water box, then cleaned them off before pulling to the line. Can't hook up now w/out my et streets.
Benji
Old Sep 16, 2003 | 11:04 PM
Kain's Avatar
If by street tires, you mean anything DOT approved: 1.65 60' on 28x11.5x15 ET Streets.
If by street tires, you mean regular old street radials, no drag radials or street slicks: 1.99 on 275/60/15 BFG Radial T/A's.
Old Sep 16, 2003 | 11:05 PM
atljar's Avatar
Best of all 3
Street:
2.11
Nitto DR
1.78
ET Streets
1.75
Old Sep 16, 2003 | 11:22 PM
Transamdriver's Avatar
2.1 60' Kumho Ecsta 712's. Stock suspension and 3600 stall.
Old Sep 16, 2003 | 11:28 PM
WOOPS! Forgot to mention, I did a pretty decent burnout, tire pressure was at 25 PSI.
One thing about Water-box burnouts, MAKE SURE U LET OFF THE BRAKE SO THAT U CONTINUE TO BURNOUT - OUT - of THE WATER BOX.
I see too many newbs at the track that do a burnout, and stay in the water box, and drive out Their tires are still wet and they end up with 60s of like 2.4.
Old Sep 17, 2003 | 08:56 PM
hvyss's Avatar
Best on BFG's 2.02
Best on BFG drags 1.81
Best on 27/10.5/15 ET streets 1.67
In a 4500 lb boat.
HVY SS
Old Sep 18, 2003 | 06:44 AM
Fastbird93's Avatar
1.923 Best of Firehawk SZ50's. Consistent mid 1.9X short times. Switch to Nitto DR's and muster a best o 1.96 one time.
Old Sep 18, 2003 | 07:25 AM
Derrick Redd's Avatar
Street: 1.97 Bridgestone Potenza RE730 (1 time only street tire run-30 psi, light burnout)
Nitto DR: 1.70 (18 psi)
M/T ET Drag: 1.55 (16 psi)
Old Sep 18, 2003 | 08:53 AM
notstock4long's Avatar
Nitto DR's, about 26psi, 1.92 60'
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
