58mm throttlebody good for a bolt-on car?
Car has LS1 Lid conversion w/ granatelli lid/k&n filter, ture duals with hooker midlengths, 1.6rr.
What I am mainly looking for is better throttle response more than hp. I know some report better response with the bigger tb's but what about on a bolt on car? Thoughts with the ls1 lid? Second question should I descreen the maf with the ls1 lid conversion if I am getting it tuned by pcm4less? |
Its overkill IMO, you dont really need to go bigger unless your going with a power adder or get into the h/c territory.
Well feel free to argue but a 58mm would be to much fo nothing.A good 52 mm would be fair enough and would give you a better throttle response.
The screen of the mass air flow is only usefull at idle.It smooth out the air so that you can have a clear idle.But when your running it act like a small restriction.I would take it off. |
Spend your money elsewhere, or just give it to me! :D
Do not remove the MAF "screen"..... its there to provide "smoothing" of the air flow under both laminar and turbulent flow conditions. It does not provide a significant flow obstruction. You will do more damage by screwing up the MAF sensor calibration when you remove the screen.
Thanks Fred. I'll leave it on in that case.
Any throttle response difference between a 52mm and a 58mm on a bolt on car? I will port the intake for 58mm if it seems at all worthwhile. For just the added throttle response I would do it but not if I am going to bog or lose power. Any bog w/ the 52mm? |
Originally Posted by always faster
(Post 4343951)
Originally Posted by Injuneer
(Post 4343957)
Originally Posted by 1LESSZ28
(Post 4343971)
Throttle response is GREATLY changed with a 58mm. Put it this way where cruise TPS used too be 12% it is now more like 6%.
(Post 4343957)
Yes you can lean it out slightly by pulling the screen BUT if the tuning is right you do not need to lean it out anymore.
What exactly do you think is so different between the LT1 and LS1 MAFs where you believe it is good too descreen one and not the other??? |
Originally Posted by 96capricemgr
(Post 4345131)
They still function the same and I believe some of the LS1 cars got the same MAF as the LT1.
Guess this comes down too do you understand how they function? |
(Post 4345161)
(Post 4343942)
