51, 61, 84
Old Mar 3, 2010 | 12:31 PM
z28_4life's Avatar
51, 61, 84
These are the codes I'm throwing on my lt1scanmater. The 84 is from the skipshift being unplugged from the original owner and the 51/61 just came on after I replaced the driver side exhaust manifold gasket. Car is a 1994 z28 m6 stock. The driver side manifold area started lightly smoking after I finished installing the gasket and started the car. I'm not sure if this is due to the fact that wd-40 was sprayed on the manifold bolts/air fitting for manifold or if it's just the new gasket material burning off from the heat. Not sure how the 51/61 suddenly came up.
Old Mar 3, 2010 | 12:39 PM
z28_4life's Avatar
fyi, 51 is EEPROM program error and 61 is AC system error.
Old Mar 3, 2010 | 12:48 PM
NewbieWar's Avatar
I thought only 93's had EEPROM?
Old Mar 3, 2010 | 12:49 PM
RamAir95TA's Avatar
From the service manual:
PCM calibrations are stored in the EEPROM (Electronically Erasable Programmable Read Only Memory). The EEPROM is not removable from the PCM. DTC 51 will set if no calibration was programmed in the PCM, or when the PCM detects an internal program fault (Checksum error). If DTC 51 sets during normal vehicle operation, replace the PCM. The replacement PCM must be reprogrammed.
Doesn't look good.
Old Mar 3, 2010 | 02:29 PM
z28_4life's Avatar
Doesn't look good.
Story of my life. I think I'll just take a 4-5k loss on this one and trade it in. Chalk it up as a learning experience Too bad cause it's only got 50k on it.
Old Mar 3, 2010 | 02:31 PM
RamAir95TA's Avatar
Out of curiosity, does the car still run?
You can pick up a PCM relatively cheaply. I wouldn't give up on it just yet.
Old Mar 3, 2010 | 02:50 PM
z28_4life's Avatar
Yea, I disconnected the battery to let the pcm reset and 51, 65 have not come back so I'm not sure what happened. I'm still getting smoke coming from the driver side header. I've had new coated headers smoke upon initial start up but I'm not sure if gaskets are supposed to have a similar reaction to the first heat cycle once started. The only reason I swapped out the manifold gasket on the driver side is because i was getting a tick around 2 grand. After checking all the spark plugs/boots on that side I decided to swap out the gasket. The old one literally split in half and the back 2 bolts were fairly loose on that manifold. I'm gonna go take it for another test drive real quick to see if I still have a tick. Hopefully, it doesn't start on fire.
Old Mar 3, 2010 | 04:46 PM
51 can be tripped by a power glitch. It happens sometimes. No reason to panic as long as it runs (and does not come back).
Old Mar 3, 2010 | 04:49 PM
93s have PROMs [EPROMs]. 94+ have EEPROMs.
