4+7 Swap
Old Aug 14, 2007 | 03:18 PM
  #31
reamo04's Avatar
I am running one in my LT1 setup purchased the cam from Cam Motion. You have to remove the opti, weld the opti drive hole shut and machine it smooth and flat, so you can run a cam button. As for the pcm all you need to do is swap 4 and 7 spark plugs on the distributor.
SBC and LT1-4 firing orders 18436572 with 4/7 swap 18736542
thats from my local fbody site
Old Aug 14, 2007 | 05:08 PM
  #32
Dave89IROC's Avatar
Originally Posted by rock1501
since I already have the cam if all I have to do is swap 4/7 plug wires and injector wires thats awesome
5-6 rwhp is cool with me every bit helps
I already have long enough wires anyway because they run all the way to the back of the engine to the distributer(oldskool style)
I was thinking I could change the firing order through my programable digital 7 box but that would only help me with spark and not fuel since the fuel is run still off the stock pcm controlled by the rpm signal from the optical sensor in the opti
I guess I could only change the 2 plugs on the injectors and change the firing order through the msd box right and leave the ignition wires as is right?
thanks for the help guys
Dave
I would just swap the 2 injector driver wires at the PCM connector
Old Aug 16, 2007 | 12:11 AM
  #33
rock1501's Avatar
thanks I think that is what I will do
Old Aug 17, 2007 | 09:56 AM
  #34
chrism400's Avatar
Are you still using the stock computer?
Old Aug 18, 2007 | 02:10 PM
  #35
rock1501's Avatar
I am just using it for fuel management
I think next year I am going to ditch the computer and just throw a carb on there
Old Aug 19, 2007 | 02:10 AM
  #36
chrism400's Avatar
I want to put in this solid roller 264/270 688/660 on a 108lsa with 4/7 swap.
Dave
With your setup and that cam, your motor is definitely going to want to see above 7k for sure. That's why I asked if you were using the stock computer. How fast has your car gone so far?
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
