CamaroZ28.Com Message Board
-   -   383 (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/383-221343/)
Mike383LT1 Feb 5, 2004 01:51 PM
383
how much is too much looking to make the most power possible out of my 383 have a set of afr 210 heads and just got my accell gen 7 box need to keep on pump gas thinking of big solid roller no n2o give me some ideas thanks
WheelmanZ28 Feb 5, 2004 02:11 PM
I would like to answer, but I have no idea what your talking about. What exactly are u asking?
Mike383LT1 Feb 5, 2004 02:17 PM
383
sorry should have worded it better in a nut shell how much power can be made with a 383 and it has to be done on pump gas
Josh-'04 GTO Feb 5, 2004 02:30 PM
Assuming the proper intake/exhaust components, 550 fwhp should be attainable NA. I think you'll find the standard LT1/LT4 intake manifolds to be a bottle neck in a high end stroker...
WheelmanZ28 Feb 5, 2004 02:32 PM
With aftermarket AFR castings, I could see u definitely putting down 450-475 RWHP N/A with solid roller. What compression ratio are u figuring? I wouldn't go higher then 11.8:1 on pump gas.
