383
Old Feb 5, 2004 | 01:51 PM
Mike383LT1's Avatar
383
how much is too much looking to make the most power possible out of my 383 have a set of afr 210 heads and just got my accell gen 7 box need to keep on pump gas thinking of big solid roller no n2o give me some ideas thanks
Old Feb 5, 2004 | 02:11 PM
WheelmanZ28's Avatar
I would like to answer, but I have no idea what your talking about. What exactly are u asking?
Old Feb 5, 2004 | 02:17 PM
Mike383LT1's Avatar
383
sorry should have worded it better in a nut shell how much power can be made with a 383 and it has to be done on pump gas
Old Feb 5, 2004 | 02:30 PM
Josh-'04 GTO's Avatar
Assuming the proper intake/exhaust components, 550 fwhp should be attainable NA. I think you'll find the standard LT1/LT4 intake manifolds to be a bottle neck in a high end stroker...
Old Feb 5, 2004 | 02:32 PM
With aftermarket AFR castings, I could see u definitely putting down 450-475 RWHP N/A with solid roller. What compression ratio are u figuring? I wouldn't go higher then 11.8:1 on pump gas.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
