CamaroZ28.Com Message Board
-   -   375rwhp ,,what cam? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/375rwhp-what-cam-221385/)
Mystic97Z Feb 5, 2004 03:32 PM
375rwhp ,,what cam?
with lyod elliot p+p'd heads, and longtube headers, basic bolt ons,,what cam could you get 375+rwhp from without reving extremely high, and keeping mild street drivability?
Fastbird93 Feb 5, 2004 04:06 PM
:D
See sig, although my heads flow a little better than Lloyd's heads.
Brettinator Feb 5, 2004 04:31 PM
also take a look at the Crane GM847, it's one mean SOB and with the proper valvetrain setup will make use of decent heads like your installing. I researched for 7 months prior making my decision and hands down could not be more pleased with the results.
Fastbird93 Feb 5, 2004 04:39 PM
Problem with the 847 and ported heads is that it's peak is going to come pretty high. Upwards of about 6400+.
flyinZ Feb 5, 2004 04:40 PM
The CC 306, GM 847, or a Custom Grind, like from Mr. Overton would give u those #'s.
Mystic97Z Feb 5, 2004 04:46 PM
i was looking at
227/233 ----might be a lil small
230/236 -----read it peaks around 6500-a little too high
233/239 don't know much about
how does that zz409 cam compare to these? can u buy that in a kit? from where?
also, the 847 isn't really street drivable is it? i have to drive it almost everyday.
lt1g3n Feb 5, 2004 04:57 PM
how far off is the cc305 from the cc306 ? I didn't get the 306 right now because I can't do work on my heads till next probably next year, how much power can i pull from the 305 with nonported heads, but with new spings, 1.6 rockers, etc.
And then with fully ported and polished heads ?
Or would i be much better off with the 306 and take out the 305 next year?
Camaro_Guru16NY Feb 5, 2004 05:08 PM
[QUOTE]Originally posted by Mystic97Z
[B]i was looking at
I was also wondering how the CC306 compares to the 233/239 if anybody has any info.
_John
simple Feb 5, 2004 05:12 PM
2 words 'custom grind'
Brettinator Feb 5, 2004 06:30 PM
First I've heard that and not a problem at all, well at least on mine and so far others that are using it, you're valvetrain configuration also plays a big part in the peak (RR specs, etc, etc). It's all relative to the rest of your engine configuration and good PCM tuning.
ibanez6rg Feb 5, 2004 06:33 PM
The 306 cam is 230, 244 on a 112.
Fastbird93 Feb 5, 2004 07:00 PM
I understand that completely. My point is that on a stock short block you inherently run a much greater risk of spinning the motor up that high. I've heard of people going as high as 6800 on the stock bottom end, but personally I would be very careful. Another point in that is that spinning that high is pretty much pointless on the street, and the starter of this thread did want driveability in a street car.
Don't get me wrong, I think the 847 is an outstanding cam, and have considered a swap to it myself if my 224/230 setup doesn't work out like I'm hoping.
Robs97Z28 Feb 5, 2004 08:04 PM
http://www.tpis.com/
All TPiS hydraulic roller cams have a cast iron distributor gear. This allows you to use the stock distributor gear.
ZZ-9 HydraulicRoller:
Intake Exhaust Advertised duration 282 287
Duration at .050 212 226
Gross lift .483 .520
Lobe separation 112
ZZ-409 Hyd Roller:
Adv. duration 287/287, duration @.050 226/226, Lift .520/.520. 112 LSA.
ZZ-9X Hyd Roller:
duration @.050 225/240, Lift .525/.558 on a 112 LSA. ZZ-X Hyd Roller:
Adv duration 290/290, duration @.050 239/239, Lift .558/.558, on a 112LSA.
*This cam uses #700-132 springs. All lift numbers shown are with a 1.5 rocker. To get lift number with 1.6 rocker, divide lift number by 1.5, then multiply by 1.6. Call to discuss, 952-448-6021
700-117 ZZ-9X Camshaft 95-97 LT-1........$375.00
700-118 ZZ-9X Camshaft 87-94 L98 & LT-1........$375.00
700-119 ZZ-9X Camshaft Flat nose/early block........$375.00
700-120 ZZ-409 Camshaft 87-94........$375.00
700-121 ZZ-409 Cam 86 and earlier........$375.00
700-122 ZZ-409 Camshaft 95-97 LT-1........$375.00
700-125 ZZ-X Camshaft 87-94 L98 & LT-1........$375.00
700-126 ZZ-X Camshaft Flat nose/Early Block........$375.00
700-136 ZZ-9 Camshaft 87-94 L98 & LT1........$375.00
700-141 ZZ-9 Camshaft Flat nose/Early Block........$375.00
700-142 Cam, 1995-1996 LT1........$375.00
700-143 ZZ-X Cam Shaft 95-97........$375.00
hope this helps
Mikey 97Z M6 Feb 5, 2004 10:30 PM
Re: 375rwhp ,,what cam?
The cam I'm running is right up your alley. It's a XE 224/236 ground on a 112lsa instead of the normal 114. I made 372rwhp (corrected) with the stock throttle body, shorty headers, DIY heads, non-electric water pump through the mufflers and maxing out the stock injectors in the process (no AFPR, just LT1_Edit).
It makes peak power at 6100-6200 and I shift at 6400. I've driven this car a lot with 3.42's and 4.10's and to be perfectly honest, the 3.42's weren't that bad.
Best MPH was 115 but my crappy driving could only muster a best of 12.39. :D
Mike
1982z28with18s Feb 6, 2004 12:24 AM
Give Lloyd a call and he'll get you a badass custom grind cam to match the heads(by none other than Joe Overton). Being a 6 speed, 375rwhp will be pretty easy.
