355 LE Dyno tune this Friday...Guess my numbers
Old Apr 3, 2008 | 07:10 PM
  #256
wrd1972's Avatar
Originally Posted by 1redTA
damn speed demon If I knew your cam was going to be such a problem.... Any way it pulls to 6800 on my car.... NO tune, stock 24lb fuel system. The plugs look a little lean, but the car pulls hard. The motor has approx 400 miles as of yet I will keep a close look out on the behavior fo the motor now. Art
Welcome to the party, what valve springs and ratio rockers do you have Red?
Old Apr 3, 2008 | 08:35 PM
  #257
dangalla's Avatar
setting things up correctly and proper geometry are key, you will be fine as will the rest of the people running this set up
Old Apr 3, 2008 | 09:06 PM
  #258
speed_demon24's Avatar
Originally Posted by wrd1972
The golds are a good bit stronger than the beehives. I want to avoid overdoing things any more than at all possible even if it costs another set. Things are overdone enough right now.
Again I can see the float in the Datamaster logs and I can check #1 cylinder's spring pressures and have the car back together in 20 minutes. If I have to check the 3-4 times a year so be it to ensure things hold up.
If the my beehives were simply just slightly under par for my combonation of components then the golds should provide the valve control I need. Thats the plan right now. The Comp 921 KIT I got for free, I might make $600.00. These spring swaps are costing me nothing but my time.
If you are going to a double spring you need to setup up the pressure. If you are going to go with the golds I would go with the new 918's instead since they have an increased spring rate over the old 918's/pac springs. They are also nitraded unlike the 1218's.
Old Apr 3, 2008 | 09:15 PM
  #259
marshall93z's Avatar
I doubt he'll run 918s anytime soon!
Old Apr 3, 2008 | 10:22 PM
  #260
Well we have tapped every angle to every valve related topic in this thread but this one, so here goes.
I cant see the weight of the spring being as much a concern as a moving object like the lifter, push rod, rocker and valve. The spring does not really reciprocate in the same manner as those components. I would even tend to think that springs factor little into the equation in terms of weight. The acceleration and decel forces seem to be to me much different. The whole inertia law seems different.
Maybe I am wrong.
The weight on the cam side of rocker is nowhere near as important as the valve side, so don't be worried too much with lifter or pushrod weights.
With the beehives, you have a smaller retainer than regular springs PLUS the top coils are smaller then typical springs and that is the part of the spring that is constantly moving, therefore equaling less weight moving.
Old Apr 4, 2008 | 06:27 AM
  #261
1redTA's Avatar
re
wrd1972 I am running nsa pro mag 1.6 with springs that were on the heads when I got them, uuuhhh so I don't know. Traded a motor that went 10.40 for these heads and cash. I just wanted to put something on that should be real fun. If the springs wear out I guess this will be real fun.Art
Old Apr 14, 2008 | 08:25 AM
  #262
Yeahdoug's Avatar
Did you swap springs? Any results?
Old Apr 14, 2008 | 08:42 AM
  #263
black96z28's Avatar
He has changed his springs should know very soon the results and I am changing my springs too so we should know on mine by the first of next week if its fixed too.......
Old Apr 14, 2008 | 08:45 AM
  #264
96capricemgr's Avatar
http://ls1tech.com/forums/showthread.php?t=901593
Old Apr 14, 2008 | 09:30 AM
  #265
wrd1972's Avatar
Update:
I installed the PSI LS1511ML beehives at 1.765" install height. Pressures are 130#/360#.
Went out and hammered on it and logged everything on datamaster.
NO IMPROVEMENT PERIOD.
The AFGS is still falling off at 6K RPM and the motor sounds very rough. Drop under 6K then everything is golden.
Lloyd and Brett state that the PAC 1218's are sufficient with this cam setup at 1.750". The PSI's are stronger especially open so it appears that even more pressure is needed.
Next options to consider short of replacing the cam are dropping to 1.5 ratio rockers to get the lift down to the .560's, installing a rev kit, pray for a miracle. This makes no damn sense. Again Brett and lloyd claim this works and there are guys on this board running the same cam with no issues.
Old Apr 14, 2008 | 09:53 AM
  #266
black96z28's Avatar
Now this has me worried that my springs I bought is not going to work either......
Old Apr 14, 2008 | 10:43 AM
  #267
Like I said on the other forum the springs you used are stronger over the nose but weaker on the seat and it is possible to bounce the valve off the seat so there is still possibility it is float.
If you have access to a set of 1.5s that would be probably the easiest way to check it.
Old Apr 14, 2008 | 11:35 AM
  #268
What I said on ls1tech...
Wow, less on the seat! With aggressive ramps, less seat pressure will make valve bounce more of a possibility! When that valve closes, you want it to STAY closed.
Old Apr 14, 2008 | 11:45 AM
  #269
ulakovic22's Avatar
Just saw that you had 146 on the seat with the other springs and you dropped down to 130? Definitely shim them up and check your clearances to get that back up.
Old Apr 14, 2008 | 11:57 AM
  #270
Stl94LT1's Avatar
Here's something to look into. I thought I had a valve float problem. Tried reshimming the valve springs amongst a few other things. Nothing worked. Finally one day I thought I had bent a valve. I put air in the cylinder that I thought was affected, and you could hear air coming back through the intake. Pulled the head knowing I had a bent valve, took it to the local machine shop. No bent valve. The heads had been machined wrong when I had them ported, and the valves weren't sealing properly. The valve seats had been machined off center to the valves. CNC Cylinder HEADS was the original head porter.
I wouldn't hurt to do a leakdown test on a few cylinders, to eliminate the possibilty of a case of bad machining.
