30lb Injector question
If i put it 30lb injectors do i need a bigger fuel pump or will a stock fuel pump work ?
thanks |
Re: 30lb Injector question
Fuel pump should be fine depending on your other mods. Should have your programing re-done.
The stock fuel pump will work. It should support ~400 fwhp.
| All times are GMT -5. The time now is 06:35 AM. |
