30 LB Injectors Causing Issues
Old Oct 13, 2007 | 05:50 PM
Jeffs94Z28's Avatar
I just did ported heads,rockers,cam and also 30 lb ford svo injectors. The car has been sitting around for 2 years and the gas is obviously bad. When I start the car it runs real rough (i don't drive it round or keep it on for long). The gas is probably part of the issue but would a non-tuned PCM be a definite problem? Thanks guys.
Old Oct 13, 2007 | 06:12 PM
raroz28's Avatar
It won't run good, but it should run.
You need a tune for a cam and bigger injectors, trust me I been there.
Old Oct 13, 2007 | 07:49 PM
razor02097's Avatar
how big is your cam? Its not in your sig... A big cam will make for a rough idle but put some fresh fuel in with some fuel system cleaner
Old Oct 13, 2007 | 07:52 PM
dangalla's Avatar
bigger injectors and no tune is a big no no, you are going to wash down you cylinder walls with fuel
Old Oct 13, 2007 | 08:04 PM
Jeffs94Z28's Avatar
Thanks guys you made me calm down a little bit. I'll let you know how it goes, btw its a CC306 from AI.
Old Oct 13, 2007 | 09:00 PM
raroz28's Avatar
put stockers back in until you get a tune.
Old Oct 14, 2007 | 12:37 AM
Jeffs94Z28's Avatar
I'm going to get a quick tune from madz28 in the mean time so I can drive it to the dyno tune place.
grabbem88
Apr 16, 2015 06:57 PM
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
