3:73 Or 3:90 Or 4:10
#16
I have had 3.73s in for about 10 years. I would tend to agree with comments about 3.73 street use in the lower gears. The downside is use of the .5 OD 6th gear. I have to be going 70 mph and on a flat straight highway to make use of 6th and to keep RPMs at or above 2k. My engine doesn't like to cruise in 6th below 2k RPMs.
#19
4.30's and 4.56's will be weaker than a 4.10/4.11. There will be more teeth.
I have a m6 car with 3.73's, i plan on a power adder later on so no need for a 4.10. I like them, they are silent and enough for what i need. The ratio you run has a lot to do with your own personal taste. You have to think what you want out of it and then pick accordingly.
