1st time to track
1st time to track
Im going to englishtown , NJ, on wednesday and was wondering with around mid 70 degree weather and low to high 60% humidity wha should i be looking for with a pretty much stock car, (4.11's, injectors, cat back flowmaster, vortech intake elbow, A4 tranny)? How should i launch i can get the rpms up to near 1400-1500 rpms b4 they slip (with the brake applied) should i keep it in D or OD? Englishtown, im pretty sure is around 60 feet above sea level. Thanks guys im kinda nervous lol
Re: 1st time to track
Why do you have injectors for a stock motor'd car? If you don't have tuning for them you're going to be running WAY too rich. I'de keep it in D incase it trys to shift into 4th through the traps. As car as the launch, its your car only you can figure out how to launch it.
I know i want those injectors out, i need to get sum stocks, the guy hew owned it b4 wus using spray so i guess he wanted it for the setup. i need a tune if i keep em but idunt know yet.
Z28Wilson
Aug 1, 2002 04:27 PM
