Lt383
Old 11-24-2018, 04:12 PM
Cokesbody's Avatar
Lt383
I’m doing a 383 for a 97 Camaro.my question is what flywheel and balancer is used? Do you still use the 350 flywheel and balancer or do I need to buy ones for the 3.75 crank? In an old school small block you woul have to run a 400 flywheel and balancer for a 383,so just wanna make shur I get rite parts because I just took engine down to machine shop and my machinist wasn’t shur either.let me kno thanks.
Cokesbody is offline
Old 11-24-2018, 08:46 PM
Super Moderator
JakeRobb's Avatar
Re: Lt383
The manufacturer of your new crankshaft will have the most reliable information on this.
JakeRobb is offline
Old 11-25-2018, 09:31 AM
Re: Lt383
Assuming you are doing an LT1 build, if are using a 1-piece rear main seal crankshaft, you need a flywheel with a specific balance weight to compensate for the missing piece of the end flange on the crank that allows the rear main seal to be installed. The front harmonic damper/pulley (not a “balancer”) is neutral balanced.
See post #4 in this thread:
https://www.camaroz28.com/forums/3rd...6/#post6987414
Injuneer is offline
Old 11-25-2018, 09:42 AM
Cokesbody's Avatar
Re: Lt383
Ok so, it’s lt1 based yes.it a used crank n rods i bought out of another lt383 set up... I was reading up on so other posts,and read that all 86 and up 1 peice cranks are neutral balance in the front and external in the rear,meaning the stock flexplate that’s weighted and the stock pulley should be right for application??? Correct
Old 12-26-2018, 06:05 PM
87Aerocoupe's Avatar
Re: Lt383
You can actually do it either way, when I built my forged 383 I had my machine shop internally balance my rotating assembly and flywheel and I'm using a Fluidampr as well. Or you can leave it factory balanced neutral balanced at the front and external balanced at the rear.
87Aerocoupe is offline
WRuiz
3rd Gen / L98 Engine Tech
06-22-2016 11:05 AM
SSTAT
09-25-2014 01:56 PM
Gio93z
04-04-2010 12:59 AM
hosspwr94
Advanced Tech
12
07-23-2007 08:22 AM
LT1CST
01-05-2007 10:10 AM
Quick Reply: Lt383
