1994 z28 problem
Old May 18, 2012 | 02:27 PM
clcam97's Avatar
1994 z28 problem
Hi, recently my car started acting up. While driving, the fuel cuts off for a split second at all times, and sometimes at a dead stop it stalls. The only thing I noticed so far while it cuts off, the tach and speedo gauges move up and down too. Any ideas what it could be? BTW my car is completly bone stock, LT1 automatic
Old May 18, 2012 | 02:45 PM
Guest47904's Avatar
Guest
Re: 1994 z28 problem
Do you know the fuel (pump) cuts off?
Old May 18, 2012 | 02:54 PM
clcam97's Avatar
Nope! would that be the most likely cause?
Old May 18, 2012 | 02:57 PM
Guest47904's Avatar
Guest
Well before you say "the fuel cuts off" get a fuel pressure gauge and check the pressure at the times it cuts off. Get one with a hose and tape it to the windshield if you have to drive to get it to happen.
Old May 19, 2012 | 01:56 AM
NUR2S's Avatar
Try looking for an electrical short-most likely the terminal behind the battery on passengers side is loose.
Noenav
Mar 1, 2019 07:38 AM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
cmdeshon
Jan 4, 2015 11:15 AM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
