1994/1995 harness interchangable?
v6-v8 swap...
It's a 1995 3.4L chasis.
1994 LT1 Engine (to PCM) harness
1994 Dash harness (3.4L 5.7l shouldnt make a difference)
1995 engine fusebox/wires (untouched from the 3.4L)
Do i need to change anything else out? I've herd I need the engine fusebox/lights/ect harness that runs through the drivers side shock tower is this true? It should be the same...shouldn't it...
thanks guys.
thanks guys.
From what I've looked up:
The "problem" is with the dual fan's. There is no wire/relay for them.
-Anyone have a quick how-to to get these fans going?
-are there other differneces between the '94 and '95 fuse/relay/front harness I should know about?
lol... or is that all BS? lol
my dash harness matches my engine harness, but what im worried about is the underhood fusebox.
i need to "fix up" a wire/harness and run them from the fans to the pcm...
what do you mean the engine/dash harness need to match up? like 1994 engine harness 1994 dash harness right? (in my 1995 chasis...) I am removing the 1995 dash harness...
lol, you had to see how neat the '95 harness was compaired to my 1994 harness.
I had them both sprawled out on two seperate tables, there was a buttload of wires lol.
Def. different in the c100 c105 ect, I had to work my way around the aftermarket alarm cluster f^!k
Anyone know where I can find a diagram for the brake light clicky thingie with the 4-5 wires? (illuminates the rear break lights when you apply the break peddle)
I hope I connected the "missing parts" correctly, I would still like a 1994 dash harness diagram if anyone know's where to find one. (Shbox?)
thanks for hangin there with me guys, i can't wait to get it started.
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
