1993 lt1, new msd opti spark and new time cover seals
Old May 6, 2013 | 11:10 AM
anmar A's Avatar
my 2 year old opti just went out AGAIN, and i am replacing it with a new MSD opti spark, i will be doing it myself this time, i took all of the parts off right now (WP, WP seal, crank pulley and hub, old opti) and am planning on replacing the seals, is there a seal for the opti on 1993 non vented ones? how can i get the timing of the opti right, i did open my old one before i removed it and marked the location of the rotor, new MSD comes completely assembled, so do i have to open it and make sure the rotor is in the right location, is there an easier method?
any help would be appreciated!
Old May 6, 2013 | 12:19 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Re: 1993 lt1, new msd opti spark and new time cover seals
Unless you've already purchased the MSD opti, I would suggest you consider going with AC Delco or Delphi.
Old May 6, 2013 | 04:00 PM
This is how you index a spline drive opti.
Old May 6, 2013 | 05:05 PM
You should open your shiny, new MSD Opti (and any other brand Opti) and loc-tite the rotor screws, or you'll be back here in a few weeks asking why your engine is misfiring or won't run.
Old May 12, 2013 | 10:55 AM
97Z4CZ28's Avatar
Exactly you get what you pay for! Delphi made them for GM any ways yet you can get a Delphi opti much cheaper than an AC Delco opti...just sayin!
Old May 13, 2013 | 11:40 AM
anmar A's Avatar
does anybody know how to install front crank oil seal, is there a tool out there?? plus am planning on using otvc spark plug wires, this is the first time am changing the plugs on my 93 z28 so any advice on how to do it. is there a complete posting on how to do this??
Old May 14, 2013 | 08:48 AM
anmar A's Avatar
Question Re: 1993 lt1, new msd opti spark and new time cover seals
any help?? any one, is there anybody who change their front crank seal on lt1 engine, and used otvc spark plug wires who can help me out
Old May 14, 2013 | 02:00 PM
The crank seal must go on straight, flat and true. There are seal installer tools, but most probably just use a block of wood and a hammer. Sometimes it is difficult to get started. Going straight on is the most important part. If the seal gets bent, it is ruined.
Old May 14, 2013 | 02:18 PM
anmar A's Avatar
thnx for the reply i think that is the problem too it is very hard to install this seal without a tool so i bought KM J-35468 Timing Cover Aligner & Seal Installer, hope this will make it easier to install, am planning on redoing it this weekend hopefully get the tool and the new seal shipped by then, as well as my over the valve cover spark wire kit and start driving my car again. prob thinking for the next is to put a cat back maybe borla, and i would've change to long tube headers but heard it is very difficult to do, it took me 8 hours to change my exhaust manifold to pacesetter headers on my 2004 monte carlo.
Old May 16, 2013 | 03:08 PM
GCEZ28's Avatar
BTC... Are you recommending against the MSD?
Old May 16, 2013 | 08:39 PM
slick1hunting's Avatar
gce I would say he is. The ac delco and delphi tend to last the longest and have the fewest issues.
Posted from Camaroz28.com App for Android
Old May 16, 2013 | 09:16 PM
BTC's Avatar
BTC
I don't have any personal experience with their optispark. I considered buying one several years ago when I pulled my car out of storage and began the arduous task of getting it running. In hindsight, I'm glad I let myself be talked out of buying one in favor of an OEM(Delco/Delphi) opti.
I also have over the valve cover wires. I guess they are supposed to be nice if you have headers, but I'm not sure I would do it again. I would probably just route the wires under the headers and use as many zip ties as necessary to secure them. I used all MSD components, plus Made For You looms, and measured and made my own wires. It's not really that difficult.
Old May 17, 2013 | 01:58 PM
GCEZ28's Avatar
After going through 2 OEM optis I decided on the MSD. Remember, this is a 93 & 94 and is not vented. The MSD is vented AND has and adjustable spark advance. The MSD woke up my LT1.... Now, maybe my old unit was really weak, I don't know but I do know that the seat of the pants feel was a huge surprise! Sadly I had an oil seal leak after installation and it got into the MSD unit and rendered it useless. But MSD replaced it under warranty and life was good again. I would recommend the MSD Optispark over the OEM.
And anmar A... be real careful with the seals. There are post here somewhere dealing with the seals in the timing cover. And yes, replace the timing chain. The Cloyes C-3228 is the OEM that everyone seams to like. Cheap and reliable.
Old May 17, 2013 | 02:42 PM
anmar A's Avatar
Cool Re: 1993 lt1, new msd opti spark and new time cover seals
i will be working on my car this weekend, i replaced all of the three seals, so planning on putting everything back together. why should i be replacing the timing chain, my car has only 116K miles on it.
i dont think there would be any hp gain out of changing the timing chain??
Old May 18, 2013 | 07:46 AM
GCEZ28's Avatar
No Hp gain unless it were real bad i suppose, but you are right there, I did mine at 140,000 miles when I did the MSD install. It was not real loose but it was loose. I've read that no one hears of the stock unit "failing" but they do stretch and wear. It's about $100.00 and like I said, you are right there.
But, I believe removing the timing cover may disturb the oil pan gasket... Mine seams to have developed a small leak at the front of it, have not had a chance to really look at it or talk to my mechanic about it.
Anyway, have fun today! Post how it all turns out!
