1500 - 1800 rpm Stumble
My son has a 1995 TA auto trans with 72k miles. Car only has a K&N CAI and Hooker catback. Appears that the Opti, wires, and plugs are the orginals.
Last night it began to "stumble" between 1500-1800 rpm. There is no backfire. Pass 1800 rpm it pulls hard all the way to its redline. There is no SES light.
Any advice on where to begin troubleshooting?
Thanks,
DMark
Thanks,
DMark
Re: 1500 - 1800 rpm Stumble
Does it stumble after the motor is warmed up only or all the time? My car only stumbles for a second with the throttle romped and thats only after the motor has been warmed up. Some say it is the ICM getting hot and malfunctioning. Plugs a wires are just a good maintance idea and "might" solve your problem.
Originally Posted by 97s10ondubs
Dude, the plugs and wires are 70k miles old, CHANGE THEM. A new coil wire comes with them.
However, most of the plug/wire problems that I have ever had usally became worst as the rpms went up.
Camarokid24 - Its not the off-idle "blog" that is common to LT1s. This is a "stumble" that is always between 1500 to 1800 rpm. Once its pass that range it pulls good and hard all the way up to the redline.
DMark
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
