1" ARP Header Bolts? where?
Old Jun 28, 2004 | 04:36 PM
Mystic97Z's Avatar
i called jegs and summit, and they only cary 3/4" arp header bolts, where are you guys getting 1" ones from?
they said they have like a 1.675 or something in a stud, not a bolt. just need a 1" bolt.
Old Jun 28, 2004 | 04:59 PM
BUBBA's Avatar
Summit. I got mine from them. Check their site.
Mine are SS 1" 12pts.
Old Jun 28, 2004 | 05:00 PM
1racerdude's Avatar
bolts
Get ARP 3/8" x 1" standard thread with the 8 point heads for a big block.They got those.These 8 point heads make it a bunch easier to install them in tight bolt clearances.
Old Jun 28, 2004 | 05:02 PM
N2OMARO's Avatar
Is there a particular reason you need the 1"? I use the 3/4" long 3/8" diameter and a 5/16 six point hex. The 1" part # is
100-1109 for a quantity of 12 or 100-1110 for a quantity of 16. These are arp part #'s. they are black oxide 6 point 1" long 3/8" diameter 5/16 wrench. I use these because you can fit a socket on almost all of my header bolts....jet hots and hooker longtubes.
Ron
Old Jun 28, 2004 | 05:11 PM
BUBBA's Avatar
I believe the black ones are ARP-100-1209, can't remember about the SS ones.
1" insures good connection, esp with thick flanges.JMHO
Old Jun 28, 2004 | 05:18 PM
BUBBA's Avatar
The SS jobs, I believe are ARP-400-1210s
I believe the 12pts with the smaller heads give you bit more room between the heads and primaries. JMHO
Call Summit and give them the numbers and then see what they say the numbers stand for.
Old Jun 28, 2004 | 05:19 PM
Mystic97Z's Avatar
how long are the ones that come w/ jet hots? mine leak even after i change the gaskets, about 2 weeks and they leak, i think i need longer bolts, they are only going into the head like 1/4 " i think.
i got these....part # from summit
ARP-400-1109
will work right?
jet hot longtubes.
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
