1.6 RR guys , more oil in the TB?
Old Jun 1, 2003 | 11:04 PM
94Zman's Avatar
Hey guys, just had GM 1.6 rr's installed with LT4 springs. Finding that the bigger rocker design is putting more oil up into the left valve cover breather that then runs into the TB. Any ideas on this one, still want to maintain the breathering function but cut down the increased oil.... messing up the TB.
Thanks in advance
Old Jun 1, 2003 | 11:55 PM
turbo_Z's Avatar
i dunno if the RRs have anything to do with that oil. more likely its your air foil blocking the PCV hole in the TB allowing oil to get trapped in there. i took off my air foil after discovering it completely blocked the PCV system in the TB from venting air down into the crankcase. i bet most if not all are designed the same way as mine so you should check that out.
Old Jun 2, 2003 | 10:25 PM
94Zman's Avatar
Thanks turbo Z, that part is OK, its actually passing oil after new seals were installed as well. Much more that usual oil is in the TB.
HectorM52
Jul 30, 2017 11:46 AM
alliance12364
Mar 6, 2015 04:39 PM
ModdedNerd
Feb 5, 2015 04:37 AM
Red97LT1
Aug 7, 2002 05:45 PM
