1.6 Roller Rocker question.
By adding 1.6 rockers I increased my lift from 447/459 to 476.8/489.6 Would that through off my computer after it being unplugged. The car surged after startup a bit and even died the first time, and sounds a bit choppier. I know the valves are not too tight. its 1/2 turn after the up and down play is taken out of the pushrod while the lifter is on the base of the cam. I didn't think adding lift the cam would make a sound difference.
Sounds like you have them adjusted wrong. Go back over them and check.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves |
I have a 96 Z28 with the LT1...I'm lookin into putting the Crane Cams Gold Billet 1.6 Rockers....but I do not know whether to get self-adjusting, or non-self-adjusting...what do i need?
Quote from Thunder Racing...
"Thunder Racing carries several different styles of rocker arms. Self-aligning rockers are a "drop-in" replacement for the stock rockers. Comp Cams offers a self-aligning roller-tipped rocker in the Magnum line, and a full roller rocker that is self-aligning in the Pro-Magnum line. The Comp Cams rockers are constructed of chromemoly steel and are available in 1.5 and 1.6 ratios. Crane Cams' self-aligning Gold Race rocker arms are a full roller rocker constructed of aluminum. The stock valve covers can be used with any of these rocker arms without modification and they are only available with 3/8" rocker arms studs." and they go on to explain non self-aligning rockers... "Crane aluminum self-aligning rockers will not clear very large valve springs. This is not a problem for most smaller camshafts, but if you are planning to run a very large camshaft or very big springs, you may be better off converting to a non-self-aligning valvetrain utilizing 7/16" rocker arm studs. The 7/16" stud will allow less flex in the valvetrain than the 3/8" stud, which will allow you to obtain maximum performance from your camshaft. This becomes more important as you put a larger cam in the engine. The use of guideplates is also a more fail-safe method of valvetrain alignment as compared to self-aligning rockers. Stock valve covers will require minor modification with this setup. The use of guideplates requires the use of hardened pushrods. The Crane Gold non-self aligning rockers are machined to clear up to a 1.630 OD spring. The design of the Comp rockers allows them to clear very large springs, also." Hope this helps! |
