0 oil pressure
I installed a motor in a car of mine that came straight from a running car. I installed it, and figured since it was running 2 days before I wouldnt have to prime it. Well, installed the engine in my car cranked it up ran for about 20 secs and never built any oil pressure. Hooked a gauge to it and it too read 0 psi. So what could have happened? Do I need to pull the intake and prime it? I dont see why I would now that it ran for 20 secs anyways. Could the pickup tube have come loose? I'd appreciate any input, thanks.
Hmm... Yeah, I would think you should prime it anyway. It can't hurt anything. If that doesn't work, come back. LOL
Are you sure the motor in question had oil pressure before it was disconnected?
Is it full of oil? If the pickup tube came off and the pan is full of oil, you should still have some kind of oil pressure. If the motor was truly running with good oil pressure only 2 days ago, priming it would be a waste of time. |
Originally Posted by FastandBlue
(Post 6357763)
Originally Posted by RamAir95TA
(Post 6357813)
It is incredibly unlikely that the pump could just go out like that.
You say you verified the oil pressure. Did you use a known working gauge on the oil port on the side of the block? EDIT: Was this a complete long-block or a short-block? Was the intake manifold on? |
I recently replaced my oil pump and it took a good 15 seconds to make pressure. Scared the crap out of me. Some pack the pump full of grease to make it build pressure faster. Maybe someone can speak to that.
(Post 6358009)
Could anything have happened to the pump drive gear?
Originally Posted by fast-enough
(Post 6358030)
(Post 6358033)
That is what I am thinking. Was it removed? Possibly broken during the removal?
Ha! No, I'm not twelve. You said the engine was working before, but as Ram said, you don't know if it had oil pressure or not. Not only that, but just because the car runs doesn't mean you didn't get it from a place where it hadn't been primed before. Just sayin, but you're right, with the known details now it's unlikely.
(Post 6358178)
Priming has nothing to do with this situation. |
this is a rather interesting situation
as quick as you can get the intake off i would pull it to get a look at the drive - from the information already posted here that would be my first and only guess at this point., |
(Post 6358205)
He said he got the motor from a good friend of his out of a running car. If it was running, it most likely had oil pressure.
Well I yanked the intake off last night and to my disbelief the drive gear was gone, unbolted and missing. I was furious, called my friend and he was even more furious than I was. He said there was a man in his shop looking for one and he told him that he had none to spare. He called the local police and they're looking into the situation. But I had one laying around, so its together and running like a top. But thanks to everyone for their input.
