0-60 Gear Shift
If you want to drive 0-60 as fast as possible with a Camaro Z28 (LT1, M6, Stock) -
At which speed/RPM are you supposed shift gears? |
what mods (cam?? 1.6rr??) what gears (stock, 3.72, 4.10??)....If stock LT1 you should shift at 5600 (after that the power drops!!!!)
Sebastian ps. The gears/tires will be the best mod for you!!! |
So what is the maximum speed at each of the six gears? (Aprox.)
First of all don’t count 6th gear (it is overdrive, just for the cursing)...Depends on what kind of gears you have (3.42, 3.73 4.10) the speed will be differed...Are you stock?? If you are stock your 1994up M6 can probably has 3.42 gears…Just go to http://www.f-body.org/gears/ and you will have all answers…
| All times are GMT -5. The time now is 08:29 AM. |
