Z06 Maf
Z06 Maf
Hey guys, I'm looking at putting a new MAF on car. I was looking at SLP, Granatelli and the corvette maf. The corvette one looks to be the best, but I was wondering if it was reliable/compatible/whatever in an f-body car. Also my car is a daily driver in the summer.(if that makes a difference) The Granatelli's are pricy! Are they that much better-what is the deal here?
Tks for your input!
Tks for your input!
Re: Z06 Maf
The MAF is a precision measuring device. The PCM's programing is calibrated to match the MAF ... screw with the MAF and your PCM is now mistuned.
Even so called "calibrated" MAFs are still mistuned vis-a-vis the PCM.
Re: Z06 Maf
Originally Posted by 35thZ282002
So would it be feasible if I had my PCM reprogrammed? Or is it something I should wait to do until after I do more serious modss?
Re: Z06 Maf
I put a SLP 85mm in my car (auto) and it refused to shift from 2nd to 3rd gear at WOT. The MAF is one thing I will NOT mess with again until I get more cubes (IE 383 or something). As mentioned above, the MAF is finely tuned to the computer and a different one will cause more harm than good.
Re: Z06 Maf
Originally Posted by SSnow
How about having yours ported and polished? Several people offer this service or if your handy with a dremel and can slap some expoy on you can spend a few hours and save your hard earned dollars.
tommalcolm
Sep 11, 2015 03:39 PM
