Will I need injectors and a pump?
Old Apr 24, 2007 | 05:50 PM
fasteddie94's Avatar
With the mods in my sig will I need bigger injectors and a fuel pump if I add a Cheatr H/C? I'm trying to figure my costs before I take the plunge.
Old Apr 24, 2007 | 09:07 PM
SSpdDmon's Avatar
You could find a set of used 28.8lbers off an 01~02 f-body and be fine. Or, you could get some SVO 30's. Fuel pump wouldn't hurt, but isn't required.
Old Apr 25, 2007 | 06:02 AM
YBNORMEL's Avatar
The fuel system seems to be an issue that everyone has a different opinion on. Some get away with running stock injectors and pump with a H/C setup while others like myself had the fuel pump go a month after the install.
Old Apr 25, 2007 | 07:25 AM
WHPLASH's Avatar
For your mods, I would not worry about it. Not necessary at that point. Save your $$$
Old Apr 25, 2007 | 08:53 PM
So basically do the H/C swap and keep an eye on the injector duty cycle?
If that's the case I'll just go ahead and be prepared and if I don't have to, that's just more mod money!
Old Apr 25, 2007 | 11:12 PM
YoungSS's Avatar
wait til you add nitrous for the pump but i'd do the 30# injectors.
Old Apr 26, 2007 | 08:21 AM
Kraest's Avatar
Retired
That setup makes no power.
You won't need anything more than factory 28s.
I think I have a set in my garage with 10,000 miles on them. Let me know if you want to buy em
Old Apr 26, 2007 | 05:17 PM
I'm going with a different setup know. After I got to looking at it I wasn't very impressed by the cam and it wouldn't really suit what I have and what I wanted. I'm still going with a small cam and the 205 heads though.
are 99 injectors smaller than 01 02 models? I thought I read somwhere that the 01 up cars had the 28s but not pre 01 cars.
Old Apr 26, 2007 | 09:10 PM
Kraest's Avatar
Retired
97-98 and 01+ had 28#
99-00 had smaller injectors - 26#
Old Apr 26, 2007 | 09:56 PM
That doesn't really make much sense. I guess that's why I'm not working for GM though.
Well in that case I'll be getting in touch with you.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
HectorM52
Jul 30, 2017 11:46 AM
tbyrne
Jul 2, 2002 05:37 PM
