Whats wrong with this time? Input PLEASE!
I went to the track the other day for the first time, although have been driving for a while, and ran a 13.08 @113.56mph with a 2.314 60'. Thats crap. Good mph though? I Still have stock F1's and I know my 60's not to good but I know how to drive and my dad used to build/race prostocks. By the way the reaction was a .538 too. What should I expect from a set of 315 nittos?
Also, RT's don't influence your ET's.
I think 315's look cool, but are not practicle (especially if you go around curves ever with the stock panhard/LCA's). Besides, 275 width drag radials will be plenty for a car with as much power as you have, and they will likely have enough grip to show you how great the stock rear is on your car.
If you put the 315s on the stock 9" wide wheels you won't gain as much et as you would if you used the 275s because the narrow rim width will cause the tread to bow in the middle and not lay flat. Less tread on the ground means less traction no matter how wide the tire is.
Lt1son
Dec 31, 2014 01:35 PM
