What is this ticking/tapping noise?
Seems to be more pronounced after I recently used Mopar Combustion Chamber Cleaner. Clearly audible in the cabin with the windows up, and seems most prominent from the passenger valve cover.
video Thanks! |
My 02 ss has it I have been told it is piston slap but Im not sure myself. mine is louder when the car is cold, then fades as it warms
I've had this problem since Oct 2000 on a 2001 Z28. Same noise, same location. It developed 2 months after delivery, at about 2000 miles. Under warranty, GM replaced the A/C compressor and all of the plugs, as well as the headers. Nothing worked. They finally had their GM factory rep authorize pulling the pistons, finding no.2 was out of spec, and replacing it. Didn't fix the problem. They swore it wasn't a lifter, having checked and re-checked twice. I finally gave up.
The ticking quiets down as the engine heats up, and is only noticeable at idle. On very hot days, when the engine runs at the top of the normal temp range, the tapping disappears sometimes, making me suspect it really is a lifter problem. I blocked the radiator one time to run the temp up and check it out and it seemed to work. However, she runs great so I just let it tick its little heart out. Had a similar experience with an 83 Buick, the first, last and only 6 cylinder I ever owned (or will own). The engine used lots of oil from day one. I suspected the engine was running too hot, vaporizing the oil. GM tested and retested, claiming it ran in the normal temp range. Under warranty, they replaced valve guides and several other components, with no improvement. I persisted, and the GM factory rep authorized a short block. After this didn't help, I gave up at 20,000 miles and just bought lots of oil. At 45K miles it began to overheat on hot days. At 80K miles I had to replace the radiator. The problem disappeared. So much for expert GM diagnoses. Moral of the story. GM will spend thousands replacing parts if their tests say your problem isn't what you suspect it is, rather than taking a chance and spending a few hundred based on your experience with the car. Although I'm sure you have no warranty, don't let GM (or anyone else) convince you to try their cure(s). I think its either a lifter or the belt tensioner. The belt tensioner is cheaper. |
Originally Posted by iroczen
(Post 6328389)
I have a similar tick w/ my '00 Z except that I can't hear it when it's cold, only when warmed up. I'm guessing lifter tick.
Originally Posted by km9v
(Post 6329977)
I haven't ever heard anyone mention cam problems associated with the infamous ticking problem before. Perhaps its a quality problem, which would explain why some never have the problem and others can never find it.
I had the same problem with my 2001 ss but at about 500 miles and the dealer was not able to correct it. Ticks when cold and goes away when warm. Car now has 14000 miles on it. |
Originally Posted by cars3
(Post 6333132)
Ticks when cold and goes away when warm. |
Originally Posted by AL SS590 M6
(Post 6333267)
This is almost always piston slap and is not a problem at all. The piston shrinks when cold and taps back and forth in the cylinder until it warms up, which usually happens within seconds of startup.
(Post 6334115)
Mine takes about 10 minutes to go away
Originally Posted by Camaroldy
(Post 6337823)
Mine almost never goes away unless it is very hot. In fact, it seems more noticeable when it is warmed up, probably because idling speed drops. Above 900 rpm or so, its not very noticeable. At idle (550-600) its very noticeable.
(Post 6337970)
My car sounds like it's doing 99.9% the same as your car is doing, except my ticking will go away completely once warm. About 10 min.
op, have you checked for an exhaust leak around the header flange, maybe a loose or missing bolt |
(Post 6337823)
Read post #6. If you don't have an exhaust leak your discription sounds like cam lobe failure. |
My 02 z has the same tick it develops cold and then fades,after many complaints and trips to the dealer i was told it was an inherent problem of the ls1 and they would monitor it.code for we dont know !!!
It doesnt seem to bother it so oh well |
