What size wheels will fit my 2002 Camaro Z28?
What size wheels will fit my 2002 Camaro Z28? All wheels are "17 x 9" in sixe.
5.5'' Rear Spacing, 5 on 4.5'' Bolt Pattern 4.5'' Rear Spacing, 5 on 4.75'' Bolt Pattern 5.5'' Rear Spacing, 5 on 4.75'' Bolt Pattern 4.5'' Rear Spacing, 5 on 5'' Bolt Pattern 5.5'' Rear Spacing, 5 on 5'' Bolt Pattern ------------------ 2002 Camaro Z/28 LS1 A4 (2.73's) Sunset Orange Metallic Fernco, SLP Airlid, K&N Filter ----------------------- 1995 Ford Aspire M5 !Torque & !Power |
[QUOTE]Originally posted by gillbot:
[B]What size wheels will fit my 2002 Camaro Z28? All wheels are "17 x 9" in sixe. Maybe it's not your question, but Z28 wheels are 16". SS's come with 17" wheels. Also, what are you trying to accomplish, by going to a different wheel size? (handling, appearance, better acceleration?) I'm sure allot of guys, here, know the answer. But, you may want to check with a tire shop, or your dealer. Good Luck Mark |
Well, your car has a 5 lug x 4 3/4" bolt pattern, so that should help a little.
Wheels with 5" bolt patterns will not work. |
So that narrows it to:
4.5'' Rear Spacing, 5 on 4.75'' Bolt Pattern 5.5'' Rear Spacing, 5 on 4.75'' Bolt Pattern I can order a 17x9 or a 16x8 size. I prefer the looks of the 17's but my tires should change over if i get the 16's. (I have stock 16's on now) ------------------ 2002 Camaro Z/28 LS1 A4 (2.73's) Sunset Orange Metallic Fernco, SLP Airlid, K&N Filter ----------------------- 1995 Ford Aspire M5 !Torque & !Power |
