What else for MAC install?
Old Jul 30, 2004 | 08:55 AM
95TA8280's Avatar
I'm buying used MACs with high flow cats, and I'm wondering what else I need? Stage 8 locking bolts? New header gaskets? What do I need for 02s? I know for my 95 TA, when I did the headers, I got like wires from auto zone and melted them together with buttconnectors (or something like that, I cant remember) can I do the same thing here?
And when I'm done, I need to find a shop to weld my catback (LM) to the high flow cats right?
Old Jul 30, 2004 | 10:26 AM
nikkev's Avatar
Re: What else for MAC install?
Yes, VERY good idea.
New header gaskets?
I reused the stock metal gaskets.Just be careful taking them out.
Yes, you can use O2 simms and delete the cats or get O2 extensions to move the O2's back.
Unless you just want to use an exhaust clamp to keep the catback removable. Good luck!
Old Jul 31, 2004 | 05:19 AM
AL SS590 M6's Avatar
Moderator
You did good right up to here.
For the rear O2 sensors with no cats use sims or have them programmed out. If you go with cats the wires should reach the sensors.
For the front o2 sensors with Macs you may or may not need to extend the wires. I bought the premade extensions. But some have done the doityourself ones successfully.
Old Aug 2, 2004 | 01:00 PM
J0HN D's Avatar
My passenger side reached fine. The driver's side was too short. I opened up the wire loom, and pulled out the o2 wires, so I could drop the sensor down the back, instead of in the front...
Old Aug 5, 2004 | 09:14 AM
95TA8280's Avatar
Anyone else? What did you have to do with your O2s during the MAC install?
Old Aug 10, 2004 | 07:42 AM
1sloLS1's Avatar
both o2 sensors reached just fine on my MACS
Old Aug 10, 2004 | 04:38 PM
99blackSS's Avatar
I had to extend the ground wire on the drivers side downstream. Other then that 02 sensors were not a problem. I would buy new gaskets, including new AIR hose gaskets because if they were like mine there won't be a way to save them.
Old Sep 1, 2004 | 04:09 PM
danziger's Avatar
I wouldn't use the MAC cats...they are pretty restrictive. If you have to use cats, reuse your stockers (what I did), or an aftermarket set.
Nov 18, 2023 07:21 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
CobraEatr
Jul 23, 2002 06:32 PM
