Tq. Management
Old Nov 23, 2002 | 11:22 AM
tomslawsky's Avatar
Question Tq. Management
What is it? How does it work? Is there a difference in the car without it? Does it's removal affect performance at the drag strip and if so, by about how much? Will the driveline components last less time without it? Thanks.
Tom
Old Nov 23, 2002 | 03:15 PM
Camaro ChriSS's Avatar
I'm no expert on TM, but essentially it is the PCM retarding your timing at the shift points (by about 27 degrees) on an A4 LS1 - it's different for other vehicles where cyliinders will be shut of, etc... That is why when you ATAP or dyno you will see big drops in power at the shift points. I am uncertain how much good or harm would be caused by its removal. It is designed to preserve the tranny. I wouldn't expect a gain of more of 0.01-0.03 seconds off for its removal, but I could be wrong.
Old Nov 24, 2002 | 04:00 AM
GatotsuZeroshiki's Avatar
John at HPAparts told me that torque management might have a problem with the 3400/2.0 I ordered b/c of the low STR (i.e., SES light, but not sure which code though. ). I'ts nothing 550 bucks from carputing won't fix though.
Old Nov 24, 2002 | 11:38 AM
LBJ's Avatar
LBJ
Go chat with "Neustrom" on LS1.com forum. He has a 02 SS A4 with a stall ect.... and the tork management removed. He gained a couple tenths at the track with it removed!!
I have ridden in his car with and without . When he had it taken out....it holds you in the seat from the 2-3 shift. Thats around 90mph for the A4 I think...
He runs 12.4's @ 106
Hope that leads to a answer for you
Old Nov 24, 2002 | 12:25 PM
A couple of tenths from the torque Mgt alone? I find that very hard to believe. There must have been some more significant tuning involved as well, such as leaning out the fuel mix/raising timing. The elimination of TM won't gain you that much.
Old Nov 25, 2002 | 06:57 AM
tomslawsky's Avatar
How about in an MN-6 speed like my car?
Old Nov 25, 2002 | 08:47 AM
PhantomTA's Avatar
Moderator
Tom,
your car isnt an auto. You dont have it.
Old Nov 25, 2002 | 08:59 AM
tomslawsky's Avatar
Originally posted by PhantomTA
Tom,
Ahhhh...thank you!
Old Nov 25, 2002 | 11:13 AM
OliGeorgs's Avatar
If I´m not misinformed m6´s do have tq management.
Old Nov 25, 2002 | 11:57 AM
PhantomTA's Avatar
Moderator
Your missinformed.
No stick car has it, only the auto's. it has been romored that some Auto 98's didnt get it.
Old Nov 25, 2002 | 05:02 PM
OliGeorgs's Avatar
m6 tq management seems like an acceptet fact on LS-1 edit
Old Nov 25, 2002 | 05:41 PM
PhantomTA's Avatar
Moderator
sorry, thats not true
Old Nov 25, 2002 | 07:30 PM
VeryCrazyBosnian's Avatar
Sorry phantom, but you are wrong, M6es do indeed have TM...Check your facts on LS1.com...
Alen
BTW mine is also removed with Predator!
Old Nov 25, 2002 | 08:29 PM
PhantomTA's Avatar
Moderator
just because its an option, doesnt mean its really there
Its part of the A4 shift firmness table..
ALL LS1 computers have this table because the same computer can be used with the A4 or M6.
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
WPHIG2
Aug 27, 2015 06:37 AM
Aug 7, 2015 08:52 AM
