Suspension for 1K
Suspension for 1K
I need some nice suspension that will let me launch nicely with 3500 COnverter and 315 BFG drag radials.
I have SLP Subframe connectors.
I need to fit in about $1,000 maybe $1,200
simple...
www.bmrfabrication.com
lower control arms $100
relocation brackets $70
torque arm $320
eibach drag springs $270
drag shocks for rear $80
all that for under $1000 should give you some serious traction
torque arm $320
for drag you might wanna think about rod ends. the are slightly more expensive but alot stronger. poly is garbage anyways. its just a matter of time before it has to be replaced.. but w/e.
also something i heard people do for drag is to take off the front sway bar all together and put in a bigger rear sway like a 21mm. better with the power transfer i think.
gl! and member to put the front sway back on b4 ya hit the street
/tek.
/tek.
RUENUF
Mar 13, 2016 03:37 PM
