Subframe Connectors? Whats the real deal..
So I have found several posts and sites that mention that subframe connectors should have been added from the factory, the articles are some what freighting some say that the body could twist. I like taking turns pretty fast, so I hope I haven't already f**** up the body! Should I really listen to those concerns and install SFC? Any ideas and insight would help, thanks!
Re: Subframe Connectors? Whats the real deal..
there even more needed in a convertible. when i first drove down the road and hit a bump my car would rock like a boat. now with SFC it goes straight with NO rocking. i have one tiny dimple on my rear right quarter from pre-sfc twisting. check your rear right quarter in the sunlight & you'll see. by firming up the frame more power ends up at the wheels / better traction (something like that). mine are welded, some people have bolt ons. i went with BMR.
I also have the weld in's, I think BMR, just a tubular design, like these
1993 - 2002 F-Body | Sub Frame Connectors | SFC004 - Subframe Connectors, Weld-on, Tubular, Non-convertible Only | BMR Suspension - The Leader in High Performance Suspension & Chassis
I agree with 94z's post above. I have UMI weld ins, and a hotchkis STB. The difference is VERY noticeable. I point the steering, and it goes exactly where I aim it with no noticeable body roll. Go for it!
Thanks for all the input, also do you guys think that a regular welding shop can weld them on?
Gary
CARiD
Sep 7, 2015 08:21 AM
