Stupid question?
Old Mar 26, 2004 | 07:24 AM
TransAm00's Avatar
Stupid question?
I took my car in b/c my brakes were squealing. They fixed them. Then they came at me with this story that it was b/c of the Tire cleaner I had sprayed on. Since my Rims are open and my brakes are exposed, when I spray it, it collects the brake disk. Then, as I drive, etc it forms a Glaze. Well, they had to replace the pads and scrub the rotars to make it all better. My b/f called BS on their story. What do you think?
Old Mar 26, 2004 | 09:54 AM
cop_camaro's Avatar
Re: Stupid question?
Maybe, or Maybe Not!!
Easy fix!! When you put (spray) tire cleaner
Cut a piece of cardboard exact same size as your wheel rim. When you spray the cleaner hold the cardboard on wheel and will keep spray of and out of brales! Very easy and the cardboard will dry and you can use it over and over.
I have done it for years on all three of my cars, and it works GREAT!!
Old Mar 26, 2004 | 11:50 AM
USHotRod's Avatar
Been doing it with nothing to cover it for 21K miles and I have no squeakage yet. Find it really hard to believe that one time caused it.
Old Mar 26, 2004 | 11:59 AM
SSpdDmon's Avatar
The reason I was always given was...
"Your brakes are metallic and that's why the squeel. Sometimes there are certain particles that get exposed in the pad that are going to react differently with the rotor. That's why they squeel sometimes and not all the time."
Now, the dealer may have been blowing smoke up my a$$....but, I'd believe that before the line they gave you about your tire products.
Old Mar 26, 2004 | 12:13 PM
adam_3's Avatar
Mine make noise almost all the time. From what I've heard it's just because the pads are metallic. With metal on metal you are bound to get a little sqeaking. Then you have break dust build up, your pads can glaze over. Sometimes your brakes will squeak because the pad starts vibrating inside the caliper. That's why they make that brake stuff you put on the back of your pads.
Old Mar 26, 2004 | 02:17 PM
2000TA's Avatar
Well the semi matallic has metal particals in it and that is the reason you get the squeel this does not happen all the time but it is known to happen and commenly too. they are better breaks but you take your chances with the squeel.
Old Mar 27, 2004 | 03:49 AM
Lucas Black's Avatar
just once i had my brakes squeel after washing my car and using tire cleaner.....it only squeeled during one use of the brakes though.....
Old Mar 27, 2004 | 09:54 AM
Onez4u2bn's Avatar
Same thing happened with me. I JUST got my rotors turned and brand new brake pads put on (Bendix pads) and they squeak a little. I heard cause its new pads and the metal thats in it to. Takes some miles to find thier groove (where they want to sit) They are getting better before it was like an ear piercing sound. Its been 2 days and they improved dramatically.
Im not sure about the cleaner thing, sounds iffy to me but im still a new driver to and Ive only changed oil one time in my life which was yesterday if that tells ya anything
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
