Strange throttle response??
Old Aug 14, 2006 | 10:38 PM
Boomer_Z/28's Avatar
Just started recently. When my 99 z/28 is sitting at idle, after a few minutes the rpms begin to rise without me touching the pedal. It only rises about an extra hundred rpms, then it drops low and comes back to its normal idle. When this happened, I blip the gas just up to 1500, the engine revs up, and then sort of hangs there for about 5 seconds, like something is holding the engine steady at 1500 rpms, then it slowly dies down idle again. What is making it stick like that? Any help would be great.
Old Aug 15, 2006 | 12:18 AM
GhostZ28's Avatar
Re: Strange throttle response??
maybe a dirty iac or tps? I dont know, i didnt think that was abnormal. Sometimes mine does the same thing but only as often as once every couple weeks, and other times it acts normal.
Old Aug 15, 2006 | 03:31 PM
Bayer-Z28's Avatar
Spray your throttle plate down w/ some Sea Foam. Get the passages at the top too. Or you could just take the IAC off itself and clean it.. THat usually helps a LOT.
Old Aug 16, 2006 | 08:57 AM
AL SS590 M6's Avatar
Moderator
IAC is making changes to maintain the idle. You probably need to clean it.
Old Aug 16, 2006 | 12:09 PM
SSpdDmon's Avatar
Is the car modified? If so, what mods? Cleaning the IAC valve will help some. You may have to clean the MAF too. If the car is modified (ie cammed), you may have to play with the set screw on the throttle body.
Old Aug 16, 2006 | 12:17 PM
Just some basic mods: lt headers, magnaflow cat back, lid, ssra, maf.
sorry to ask, but what is an iac? im still pretty noob on learning about modding my f-body.
Old Aug 16, 2006 | 12:43 PM
stingercamaro's Avatar
iac = idle air control
Old Aug 16, 2006 | 01:44 PM
SSpdDmon's Avatar
The IAC is a valve that mounts on the side (drivers side I believe) of the throttle body. It allows air to pass into the intake as it opens. It's used in conjunction with minor spark advances and spark retards to maintain a desired idle speed. You should check a manual (usually sold at Autozone type places) for more info. It's not rocket science though...
Old Aug 16, 2006 | 03:19 PM
GhostZ28's Avatar
ya its definately not rocket sciencce, if you are even a beginner to tools, this should be easy for you to do.
It takes me about 10 minutes to get the throttle body off and the iac taken out. you could do it easy.
Now the IAC is the little metal part held in with 2 star screws and a plastic base. It also has an electrical connector on it. And be careful to not drain coolant all over your belts when you pop off the TB coolant hoses.
Old Aug 16, 2006 | 05:07 PM
What particular cleaner i should use once i have it dismantled? And is there anyway to keep it from doing this again?
Old Aug 16, 2006 | 05:37 PM
mook99TA's Avatar
MAF cleaning solution they sell it at your local parts store.
Old Aug 16, 2006 | 06:09 PM
GhostZ28's Avatar
Dont drive your car? carbon build up will always happen.
Clean off your MAF too. Pull it out and spray down the three small wires but dont touch them. if they break you bought an expensive part...
Old Aug 16, 2006 | 06:24 PM
lol alright. thanks for the help guys
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
Rittmeister
Aug 12, 2015 03:50 AM
KYWes
Aug 10, 2015 07:03 PM
techstar
Aug 6, 2015 11:20 AM
