Starter Removal
Hi:
I want to drain the coolant on my 99 Z28. Getting the right rear drain plug out may involve removing the starter. The manual says that one must drop the Y pipe to do this. Looking at it I can't see why this is required; I must be missing something. Has anyone had bad experiences in draining the coolant; I like to drain the block every few years. Chevy doesn't draiin the coolant; they run it thru some sort of reprocessor. That worries me. |
I see no reason why you couldn't just unhook the low oil sensor and pull the 2 starter bolts to swing it out of the way for access to the coolant drain plug.
Make sure that you drain the other side too. The plug for that side is behind the alternator. |
Originally Posted by howey
(Post 4547195)
Hi:
I had to do that last summer. Just unbolt the starter and swing it out of the way and you'll be able to access the bolt. Don't forget to cover the cable post with a rag or something to prevent sparking (if you're not disconnecting the battery).
No need to drop the Y-pipe :no:.
| All times are GMT -5. The time now is 04:25 AM. |
