spark plugs
Old Oct 30, 2002 | 09:54 PM
toddfather's Avatar
Question spark plugs
having trouble removing/insatlling plugs in pass side of 98 z28.seems to tight a space to get rachet in there.should i come in from top ands take all pluming out or from the bottom and move starter and exhaust.any ideas and or tips would help me out.car is running terrible.makes me loose sleep at night.also talked to several part stores,no one can give me a straight answer,are the two o2 cencors the same or are there two different part #`s.
Old Oct 30, 2002 | 10:14 PM
LS1C5's Avatar
I assume that you have removed the air tube and taken off the coilpack? Given you've done that you should be able to reach in and put the spark plug socket on plug number 8. What I do then is get a socket that fits over the sparkplug socket and using my ratchet remove the plug.
Old Oct 31, 2002 | 11:31 AM
NEWBIE T/A's Avatar
Unhappy I paid to have mine done, so ...
I am unable to give firsthand advice !!
However -
http://www.installuniversity.com/
in the install documents has a great write-up on plug changes.
Hopefully, it will be of help.
They have a lot of other info as well.
Good Luck !
Britt
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
