spark plug question...
Old Aug 16, 2006 | 07:31 AM
grannycar's Avatar
new to ls1's so bare with me...
planning doing spark plugs on my 00 trans am i pulled on out to check it. (i just bought the car) the gap on it was like .070 inches what is the gap supposed to be on these? and the plug said AC so i was assuming they are origanal? and how the heck do you do the passenger side plugs? do i have to take the air pump line off? and for the one in the back do i have to get it from undernethe?? also what brand are good to get? sorry if I got alot of questions im just new to ls1's. came from mustangs! thanks!!!
Old Aug 16, 2006 | 07:38 AM
Capn Pete's Avatar
Re: spark plug question...
- The gap for stock plugs should be .055" I believe.
- The original plugs are AC Delcos.
- for a replacement, get NGK TR55's (iridium IX's if you're feeling rich)
- it will make it easier doing the passenger's side to pull the air tube off the manifold
- yes, get #8 from underneath
- glad you're out of the 'Stang phase and into a real performance car!!
Old Aug 16, 2006 | 07:54 AM
grannycar's Avatar
thanks for the help! hey i still love mustangs!!! lol i at least had
the 4.6 pi motor!
Old Aug 16, 2006 | 12:49 PM
98mustang_vert's Avatar
Check out http://www.installuniversity.com/ins...sity/index.htm click on Install Documents and scroll down to the Engine section, there should be a link to spark plug and wire change. It's a good write up, I used it when I changed mine. Yeah the passanger side is a pain especially #8, go from the top, remove the AIR tube, kneel on your car battery to reach the 8th plug with an spark plug socket and a 1" extention. I tried getting it from the bottom but the stock manifolds got in the way. With headers I've heard it's much easier from the bottom. Good luck. After you're done you'll be glad you didn't take it to a shop where they would have charged you $300+
Old Aug 16, 2006 | 01:46 PM
SSpdDmon's Avatar
Changed mine from the top in 2.5 hours last weekend (NGK TR55's gapped at .055). Remove the AIR tubes and the passenger side coil packs. Then you should be good to go. We would have been done in less than 2 hours, but a friend stopped by to chat and we started to disconnect my AIR system.
Old Aug 16, 2006 | 02:36 PM
Bayer-Z28's Avatar
Nothing wrong w/ Stangs!.. . Saw a NICE one today... Dragged out, 2500lbs!
Anyway.. Yeah, have fun w/ the plugs. There's scads of room from underneath, compared to up top... It might be easier on cuts and bruises if you took the coil packs out of the way, and the EGR/ AIR stuff.
Old Aug 16, 2006 | 06:50 PM
Greed4Speed's Avatar
Remove the coil packs when you change them and you can reach from the top. When you put them back, just leave off the hard to reach back bolts. Headers help too.
Old Aug 17, 2006 | 08:48 AM
grannycar's Avatar
thanks for the help so far! and thank you bayer! lol
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
