Which SFC's?
Old Sep 24, 2003 | 09:42 AM
  #16
DS01Z28's Avatar
Lan,
I just purchased the Dynamic MotorSports tubular weld-in SFC's for $125. The fitment was very good and they are functionally just what I needed. Through my research about SFC's, I learned that a fair amount of your decision s/b based on how built up your car is. For example, my '01 Z28 has only mild mod's, so the DD or boxed SFC's would be a bit of overkill. Not that they wouldn't work, don't get me wrong... but overkill nonetheless. My biggest decision came down to: square vs. tubular design SFC's. In my case, I could've gone either way, but I elected to go with the tubular hoping they wouldn't show as much as the boxed SFC's might've. They're in, they work fine for me, they hardly show.
Much opinion exists here about which is best. My conclusion is this: any SFC will certainly help, you just have to determine how much SFC you need or want.
Just my $.02,
Daryl
Old Sep 24, 2003 | 10:02 AM
  #17
SSCamaro99_3's Avatar
Global West.
Old Sep 24, 2003 | 11:13 AM
  #18
Lan01z's Avatar
Ok, I think i'm gonna go with the SLP bolt on. Would the qtp long tube headers still fit?
Old Sep 24, 2003 | 05:00 PM
  #19
DARK AGE 53's Avatar
Can't say about those headers but SLP long tubes worked.
Old Sep 25, 2003 | 07:59 AM
  #20
DGOETZ's Avatar
Call me crazy, but the bmr just doesn't look to me like it would support as well as the slp's would.
http://www.bmrfabrication.com/sfc/tubular2.jpg http://www.slponline.com/view_produc...&SHOWEMAIL=Off
Well you got that right.
However the SLP units are aesthetically unpleasant
I have some you might be interested in and way better that any discussed here so far.
Don
Old Sep 25, 2003 | 12:06 PM
  #21
Lan01z's Avatar
Originally posted by jeff02ss8457
I
have the SLP bolt on SFC and I have not had a problem with them at all. I never hear them rattle and have cured my rear bumper squeak. I addition to the SFC I also had a BMR Tunnel Brace added which I also recommend because the factory one just looks weak.
How much does the SLP SFC show from looking at the car from the side? It still looks fine, right?
Old Sep 26, 2003 | 08:05 AM
  #22
DGOETZ's Avatar
SFC's are not the lowest thing under the car so if your concerned about hitting I would not worry.
If your concerned about them showing then black is the color because it blends in.
If I were you I would at least take a look at what I have before you buy some thing else
Old Sep 26, 2003 | 10:16 AM
  #23
Lan01z's Avatar
Whatchu got?
Old Sep 26, 2003 | 05:03 PM
  #24
rncotton's Avatar
I'm running SpectacleSolutions double-diamond bolt-in SFC's and love them. I've got his short shift stick and STB also.
I think he sells the SFC's for $225. www.SpectacleSolutions.net
Don't believe the hype about bolt-ins not being strong enough or causing problems. I've been running them hard for over a year and when I checked the bolts before Bowling Green last weekend they were still tight.
We've got people in our club who have run them for many, many years, including several seasons of auto-x and they haven't slipped, stripped, come loose, elongated holes, or anything else.
$225 for DD SFC's with your choice of powdercoating color ... not a bad deal.
Old Sep 26, 2003 | 08:00 PM
  #25
96SFLZ's Avatar
Roger, having them welded may not make them any stronger but you know for a fact that it isn't going to make them any weaker...so I really think it's just peace of mind. There's nothing wrong with bolt-ins, just make sure to check them every so often to make sure they're still tight, that's all.
ImNraged
Aug 19, 2018 08:02 PM
HarleyZ28
Oct 5, 2015 06:23 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
rje
Sep 9, 2002 12:35 PM
