running bad
Old Jun 7, 2007 | 11:25 AM
Blackphantom's Avatar
running bad
hey guys the 98 ta that i have guys its pouring fuel out the tail pipes and smells like gas everywere.. also the car has hard time starting unless u have the foot on the floor then it idles at 2k and when u let off the gas you dont slow down u keep going and the car cruises at liek 1500k help any idead is my pcm going i had it custom tuned for the headers and lid.. also this is odd seems like it started when i put the ac line back on and cranked on the ac its creeped up slow in the past motnh i would say?
Old Jun 7, 2007 | 11:35 AM
Kraest's Avatar
Retired
Tune sounds like it's way off. Too rich and the idle is too high.
Old Jun 7, 2007 | 11:41 AM
any idead were or how much these things cost to retune
Old Jun 7, 2007 | 12:31 PM
Kraest's Avatar
Retired
Where do you live? A dynotune will cost around $500. A mail-order tune will cost a little less, but won't be as effective. You don't need anything too crazy, considering that you don't much engine work.
Old Jun 7, 2007 | 12:40 PM
im in Florida
Old Jun 7, 2007 | 01:14 PM
2000GTP's Avatar
If it is running that rich, I would be worried about washing down the cylinder walls with gas.
Old Jun 7, 2007 | 01:19 PM
come again with the walls? also jsut talked to the guy that tuned the car he said the engine coolant temp wires/ pigtail could be bad and loose and give all theses problems
Old Jun 7, 2007 | 01:55 PM
2000GTP's Avatar
If an engine is allowed to run excessively rich, it can get to the point where raw fuel will not only dilute the oil, but wash down the cylinder walls in the engine taking away the lubrication provided by the oil. When you mention you have fuel dumping out of your tailpipes, it would make me worry.
Old Jun 11, 2007 | 08:38 AM
AL SS590 M6's Avatar
Moderator
Absolutley
grabbem88
Feb 13, 2015 03:09 PM
Amshnock
14
Jan 18, 2015 11:47 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Z284ever
43
Jun 27, 2002 10:36 AM
